N306-07M
N306-07M
    TRIPPLITE
    N306-07M
N306-07M 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Duplex Multimode 62.5/125 Fiber Patch Cable (SC/SC), 7M (23 ft.) MODEL NUMBER: N306-07M Highlights ● Premium PVC 62.5/125µm multimode patch cables ● Attenuation loss meets or exceeds the latest industry standards System Requirements ● Any fiber optic hardware or NIC card requiring multimode duplex cable with SC/SC connectors Package Includes ● Features ● Manufactured from 62.5/125 duplex (zipcord) fiber ● PVC jacket ● Length: 7 meters (23ft) Connectors: 2 SC connectors on each end ● Insertion loss testing performed on every connector (0.2db typical) and provided with cable ● Beveled edge on ends of glass makes insertion of plug a breeze ● Fiber made from glass (not a polymer) ● Duplex multimode fiber is most commonly used in LAN applications ● Fiber optic distributed data interface (FDDI) rated ● OFNR (riser rated) Specifications OVERVIEW UPC Code 037332125729 Technology Multimode Optical Mode OM1 PHYSICAL Cable Jacket Color Orange Connector Color White Cable Jacket Material LSZH Cable Jacket Rating OFNR 1/3 7 meter duplex MMF cable SC/SC 62.5/125 fiber 1000 Eaton Boulevard Cleveland, OH 44122 United States Clad Diameter (microns) 125 Core Diameter (microns) 62.5 Number of Fibers 2 Cable Length (ft.) 23 Cable Length (m) 7.01 Cable Length (in.) 275.6 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.20 Shipping Weight (kg) 0.09 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit); 10 Gbps Attenuation @ 850NM 3.0dB/Km Insertion Loss 0.20dB CONNECTIONS Side A - Connector 1 SC DUPLEX (MALE) Side B - Connector 1 SC DUPLEX (MALE) Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N306-07M
PDF文档中提到的物料型号为“N306-07M”,这是一种双工多模62.5/125光纤跳线,长度为7米(23英尺),具有SC/SC连接器。
它采用优质PVC外套,插入损耗测试在每个连接器上进行,典型值为0.2dB。
光纤由玻璃制成,适用于局域网应用,光纤分布式数据接口(FDDI)评级,且为OFNR(上升器评级)。
技术规格包括: - UPC代码:037332125729 - 技术:多模 - 光模式:OM1 - 物理特性: - 护套直径:125微米 - 芯径:62.5微米 - 光纤数量:2 - 电缆长度:23英尺(7.01米,275.6英寸) - 最小弯曲半径:20毫米(动态);10毫米(静态) - 运输尺寸和重量:9.00x7.00x0.50英寸,0.20磅(0.09千克) - 环境规格: - 工作温度范围:-4至140°F(-20至60°C) - 存储温度范围:-4至140°F(-20至60°C) - 工作湿度范围:5%至85% RH,非凝结 - 存储湿度范围:35%至65% RH,非凝结 - 通信规格: - 网络兼容性:1 Gbps(千兆);10 Gbps - 850纳米下的衰减:3.0dB/Km - 插入损耗:0.20dB
连接特性: - 端A连接器1:SC双工(公头) - 端B连接器1:SC双工(公头) - 端面抛光:PC
产品符合RoHS和REACH标准,并提供终身有限保修。
N306-07M 价格&库存
很抱歉,暂时无法提供与“N306-07M”相匹配的价格&库存,您可以联系我们找货
