N318-09M
N318-09M
    TRIPPLITE
    N318-09M
N318-09M 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Duplex Multimode 62.5/125 Fiber Patch Cable (LC/ST), 9M (30 ft.) MODEL NUMBER: N318-09M Highlights ● Manufactured from 62.5/125 duplex (zipcord) fiber ● Ideal for LAN applications ● Glass fiber composition System Requirements ● Any fiber optic hardware or NIC card requiring multimode duplex cable with ST/LC connectors Package Includes ● Description Tripp Lite's 9-meter multimode duplex fiber optic ST/LC patch cable is manufactured from 62.5/125 zipcord fiber. The cable has LC to ST connectors, a PVC jacket and is FDDI and OFNR rated. Duplex multimode fiber is most commonly used in LAN applications. Features ● Manufactured from 62.5/125 duplex (zipcord) fiber ● PVC jacket ● Length: 9-meters/Connectors: 2 ST/LC connectors on each end ● Insertion loss testing performed on every connector (0.2db typical) and provided with cable ● Beveled edge on ends of glass makes insertion of plug a breeze ● Fiber made from glass (not a polymer) ● Fiber optic distributed data interface (FDDI) rated ● OFNR (riser rated) Specifications OVERVIEW UPC Code 037332134974 Technology Multimode Optical Mode OM1 PHYSICAL Cable Jacket Color Orange 1/3 9-meter duplex MMF LC/ST 62.5/125 fiber cable 1000 Eaton Boulevard Cleveland, OH 44122 United States Connector Color Black; Gray Cable Jacket Material LSZH Cable Jacket Rating OFNR Clad Diameter (microns) 125 Core Diameter (microns) 62.5 Number of Fibers 2 Cable Length (ft.) 29.5 Cable Length (m) 8.99 Cable Length (in.) 354.3 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 9.50 x 7.00 x 1.00 Shipping Dimensions (hwd / cm) 24.13 x 17.78 x 2.54 Shipping Weight (lbs.) 0.12 Shipping Weight (kg) 0.06 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit); 10 Gbps Attenuation @ 850NM 3.0dB/Km Insertion Loss LC0.20dB; ST0.20dB CONNECTIONS Side A - Connector 1 LC DUPLEX (MALE) Side B - Connector 1 ST DUPLEX (MALE) Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No STANDARDS & COMPLIANCE 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N318-09M 价格&库存
很抱歉,暂时无法提供与“N318-09M”相匹配的价格&库存,您可以联系我们找货
