N352-05M
N352-05M
    TRIPPLITE
    N352-05M
N352-05M 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Duplex Singlemode 9/125 Fiber Patch Cable (ST/ST), 5M (16 ft.) MODEL NUMBER: N352-05M Highlights ● Premium PVC 9/125 micron singlemode patch cables ● Attenuation loss meets or exceeds the latest industry standard ● Twice the bandwidth throughput of multimode cable System Requirements ● Any fiber optic hardware or NIC card requiring singlemode duplex cable with ST/ST connectors. Package Includes ● Description Tripp Lite's 5M (16.4-ft.), singlemode duplex fiber optic ST/ST patch cable is manufactured from 9/125 zipcord fiber. The cable has ST connectors on each end, a PVC jacket and is FDDI and OFNR rated. Duplex singlemode fiber is most commonly used in LAN applications. Features ● Manufactured from 9/125 duplex (zipcord) fiber ● PVC jacket ● Length: 5M (16.4-ft.) Connectors: 2 ST connectors on each end ● Insertion loss testing performed on every connector (0.2db typical) and provided with cable ● Beveled edge on ends of glass makes insertion of plug a breeze ● Fiber made from glass (not a polymer) ● Fiber optic distributed data interface (FDDI) rated ● OFNR (riser rated) Specifications OVERVIEW UPC Code 037332134899 Technology Singlemode Optical Mode OS2 PHYSICAL Cable Jacket Color Yellow 1/3 5M (16.4-ft.) Duplex Singlemode Fiber Patch Cable, ST/ST 1000 Eaton Boulevard Cleveland, OH 44122 United States Connector Color Black Cable Jacket Material LSZH Cable Jacket Rating OFNR Clad Diameter (microns) 125 Core Diameter (microns) 9 Number of Fibers 2 Cable Length (ft.) 16.4 Cable Length (m) 5.00 Cable Length (in.) 196.9 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Weight (lbs.) 0.15 Shipping Weight (kg) 0.07 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Attenuation @ 1310NM 0.36dB/Km Attenuation @ 1550NM 0.22dB/Km Insertion Loss 0.30dB CONNECTIONS Side A - Connector 1 ST DUPLEX (MALE) Side B - Connector 1 ST DUPLEX (MALE) Endface Polish UPC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N352-05M 价格&库存
很抱歉,暂时无法提供与“N352-05M”相匹配的价格&库存,您可以联系我们找货
