N504-05M
N504-05M
    TRIPPLITE
    N504-05M
N504-05M 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Duplex Multimode 50/125 Fiber Patch Cable (SC/ST), 5M (16 ft.) MODEL NUMBER: N504-05M Highlights ● Premium PVC 50/125µm multimode patch cables ● Attenuation loss meets or exceeds the latest industry standards Package Includes ● Features ● Manufactured from 50/125 duplex (zip cord) fiber ● PVC jacket ● Length: 5-meters(16ft) - Connectors: 2 ST to 2 SC connectors ● Insertion loss testing performed on every connector (0.2db typical) and provided with cable ● Beveled edge on ends of glass makes insertion of plug a breeze ● Fiber made from glass (not a polymer) ● Fiber optic distributed data interface (FDDI) rated ● OFNR (riser rated) Specifications OVERVIEW UPC Code 037332142481 Technology Multimode Optical Mode OM2 PHYSICAL Cable Jacket Color Orange Connector Color Beige; Black Cable Jacket Material LSZH Cable Jacket Rating OFNR 1/3 5-meter ( 16ft ) duplex MMF cable ST/SC 50/125 fiber 1000 Eaton Boulevard Cleveland, OH 44122 United States Clad Diameter (microns) 125 Core Diameter (microns) 50 Number of Fibers 2 Cable Length (ft.) 16.4 Cable Length (m) 5.00 Cable Length (in.) 196.9 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.17 Shipping Weight (kg) 0.08 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit); 10 Gbps Attenuation @ 850NM 3.0dB/Km Insertion Loss ST0.20dB; SC0.20dB CONNECTIONS Side A - Connector 1 SC DUPLEX (MALE) Side B - Connector 1 ST DUPLEX (MALE) Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N504-05M 价格&库存
很抱歉,暂时无法提供与“N504-05M”相匹配的价格&库存,您可以联系我们找货
