N520-12M
N520-12M
    TRIPPLITE
    N520-12M
N520-12M 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Duplex Multimode 50/125 Fiber Patch Cable (LC/LC), 12M (40 ft.) MODEL NUMBER: N520-12M Highlights ● Premium PVC multimode patch cables ● Attenuation loss meets or exceeds the latest industry standards ● Higher bandwidth, optimized for gigabit and 10Gbps networks ● Backward compatible with 62.5 micron fiber ● Built-in headroom for future applications System Requirements ● Any fiber optic hardware or NIC card requiring multimode duplex cable with LC/LC connectors Package Includes ● Description Tripp Lite's 12-meter multimode duplex Fibre Channel optic LC/LC patch cable is manufactured from 50/125 zipcord fiber. The cable has LC connectors on each end. It has a PVC jacket and is FDDI and OFNR rated. 50/125 Duplex multimode fiber is most commonly used in Fibre Channel applications. It is backward compatible with 62.5 micron fiber and provides built-in headroom for future applications. The cable provides higher bandwidth optimized for Gigabit and 10Gbps networks as well. Also available in 1, 2, 3, 5, 15, 20, 25, 30, and 50 meter lengths. Enter "N520-" in the search field to bring up all lengths. For LC-SC cables, search "N516-", and for SC-SC, search "N506-". Features ● Constructed with 50/125 micron cable ● Length - 12M ( 40ft ) ● Use on fiber and fibre channel installations ● LC male to LC male connectors ● Higher bandwidth optimized for gigabit and 10Gbps networks ● Backward compatible with 62.5 micron fiber ● Built-in headroom for future applications ● Number of fibers: 2 ● Fiber type: all glass graded index ● Core diameter: Two 50+/-3 microns ● CLAD diameter: 125+/-2 microns ● Primary coating diameter: 245+/-15 microns ● Primary coating material: acrylate ● Secondary coating diameter: 900+/-50 microns ● Secondary coating material: PVC ● Attenuation @850NM: 3.5DB/KM maximum, @1300NM: 1.0DB/KM maximum ● Bandwidth @850NM: 220 MHz-KM minimum, @1300NM: 600 MHz-KM minimum ● Numeric aperture: .275 nominal 1/3 12M Duplex MMF Cable LC/LC 50/125 Fiber Patch Cable 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Proof test level: 100,000 PSI ● Insertion loss testing performed on every connector (0.2db typical) and provided with cable ● Beveled edge on ends of glass makes insertion of plug a breeze Specifications OVERVIEW UPC Code 037332156327 Technology Multimode Optical Mode OM2 PHYSICAL Cable Jacket Color Orange Connector Color Gray Cable Jacket Material LSZH Cable Jacket Rating OFNR Clad Diameter (microns) 125 Core Diameter (microns) 50 Number of Fibers 2 Cable Length (ft.) 39.4 Cable Length (m) 12.01 Cable Length (in.) 472.4 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.18 Shipping Weight (kg) 0.08 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit); 10 Gbps; 25 Gbps Attenuation @ 850NM 3.0dB/Km 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Insertion Loss 0.20dB CONNECTIONS Side A - Connector 1 LC DUPLEX (MALE) Side B - Connector 1 LC DUPLEX (MALE) Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N520-12M
物料型号: - 型号:N520-12M
器件简介: - 这是一根12米长的多模双工光纤跳线,两端都配有LC连接器,采用50/125 zipcord光纤制成,具有PVC外护层,符合FDDI和OFNR标准。这种光纤主要用于光纤通道应用,与62.5微米光纤向后兼容,并为未来应用提供内置余量。
引脚分配: - 光纤类型:全玻璃梯度折射率 - 芯径:两个50±3微米 - 包层直径:125±2微米 - 主涂层直径:245±15微米,材料为丙烯酸 - 次涂层直径:900±50微米,材料为PVC
参数特性: - 衰减:850NM最大3.5DB/KM,1300NM最大1.0DB/KM - 带宽:850NM最小220MHz-KM,1300NM最小600MHz-KM - 数值孔径:0.275
功能详解: - 适用于光纤和光纤通道安装 - 提供更高的带宽,优化用于千兆和10Gbps网络 - 与62.5微米光纤向后兼容
应用信息: - 适用于需要LC/LC连接器的多模双工光纤跳线的任何光纤硬件或NIC卡
封装信息: - 电缆颜色:橙色 - 连接器颜色:灰色 - 电缆外护层材料:LSZH - 电缆外护层等级:2 OFNR - 光纤数量:2 - 电缆长度:12.01米(39.4英尺) - 最小弯曲半径:动态20毫米;静态10毫米
系统要求: - 任何需要LC/LC连接器的多模双工光纤跳线的光纤硬件或NIC卡
包装内容: - 12米双工MMF光纤跳线LC/LC 50/125
其他规格: - UPC代码:037332156327 - 技术:多模 - 光模式:OM2 - 插入损耗:0.20dB - 测试:每个连接器都进行了插入损耗测试(典型0.2dB),并随电缆提供 - 玻璃端部的斜面使得插入插头变得轻松
环境规格: - 工作温度范围:-4至140°F(-20至60°C) - 存储温度范围:-4至140°F(-20至60°C) - 工作湿度范围:5%至85% RH,无冷凝 - 存储湿度范围:35%至65% RH,无冷凝
通信规格: - 网络兼容性:1 Gbps(千兆);10 Gbps;25 Gbps
标准和合规性: - 产品合规性:RoHS;REACH
保修与支持: - 产品保修期限(全球):有限的终身保修
N520-12M 价格&库存
很抱歉,暂时无法提供与“N520-12M”相匹配的价格&库存,您可以联系我们找货
