1000 Eaton Boulevard
Cleveland, OH 44122
United States
Duplex Multimode 50/125 Fiber Patch Cable
(LC/ST), 20M (65 ft.)
MODEL NUMBER: N518-20M
Highlights
Premium PVC multimode patch
cables
Attenuation loss meets or
exceeds the latest industry
standards
Perfect for use with Fibre
Channel Controller Cards and
Switches
System Requirements
Any fiber optic hardware or NIC
card requiring multimode duplex
cable with LC/ST connectors
Package Includes
Features
Constructed with 50/125 micron cable
Length - 20 Meter ( 65ft )
Use on fiber and fibre channel installations
LC male to ST male connectors
Higher bandwidth optimized for gigabit and 10Gbps networks
Backward compatible with 62.5 micron fiber
Built-in headroom for future applications
Specifications
OVERVIEW
UPC Code
037332134752
Technology
Multimode
Optical Mode
OM2
PHYSICAL
Cable Jacket Color
Orange
Connector Color
Gray; Red; Black
Cable Jacket Material
LSZH
Cable Jacket Rating
OFNR
Clad Diameter (microns)
125
1/3
20 Meter( 65ft ) duplex MMF
cable LC/ST 50/125 fiber
Cleveland, OH 44122
United States
Core Diameter (microns)
50
Number of Fibers
2
Cable Length (ft.)
65.6
Cable Length (m)
20.00
Cable Length (in.)
787.4
Minimum Bend Radius
20MM (Dynamic); 10MM (Static)
Shipping Dimensions (hwd / in.)
10.00 x 7.00 x 1.00
Shipping Dimensions (hwd / cm)
25.40 x 17.78 x 2.54
Shipping Weight (lbs.)
0.23
Shipping Weight (kg)
0.11
ENVIRONMENTAL
Operating Temperature Range
-4 to 140 °F (-20 to 60 °C)
Storage Temperature Range
Operating Humidity Range
5% to 85% RH, Non-Condensing
Storage Humidity Range
35% to 65% RH, Non-Condensing
COMMUNICATIONS
Network Compatibility
1 Gbps (Gigabit); 10 Gbps; 25 Gbps
Attenuation @ 850NM
3.0dB/Km
Insertion Loss
LC0.20dB; ST0.20dB
CONNECTIONS
Side A - Connector 1
LC DUPLEX (MALE)
Side B - Connector 1
ST DUPLEX (MALE)
Endface Polish
PC
FEATURES & SPECIFICATIONS
Push/Pull Tabs
No
Breakout
No
Trunk
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
2/3
Cleveland, OH 44122
United States
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N518-20M”相匹配的价格&库存,您可以联系我们找货
