N320-15M-RD
N320-15M-RD
    TRIPPLITE
    N320-15M-RD
N320-15M-RD 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Duplex Multimode 62.5/125 Fiber Patch Cable (LC/LC) - Red, 15M (50 ft.) MODEL NUMBER: N320-15M-RD Highlights ● Manufactured from 62.5/125 duplex (Zipcord) fiber with Red jacket ● Length: 15 meter Connectors: LC connector on each end ● Insertion loss testing performed on every connector (0.2dB typical) System Requirements ● Any fiber optic hardware or NIC card requiring multimode duplex cable with LC connectors Package Includes ● Description Tripp Lite's Red, 15-meter multimode duplex micron fiber optic LC/LC patch cable is manufactured from 62.5/125 zipcord fiber. The cable has LC connectors on each end, a PVC jacket, and is FDDI and OFNR rated. Duplex multimode fiber is most commonly used in LAN applications. Ideal for color coding the cable plant. Features ● Manufactured from 62.5/125 duplex (zipcord) fiber ● Red PVC jacket ● Length: 15 meter Connectors: LC connector on each end ● Fiber made from glass (not a polymer) ● Fiber optic distributed data interface (FDDI)and OFNR rated Specifications OVERVIEW UPC Code 037332138965 Technology Multimode Optical Mode OM1 PHYSICAL Cable Jacket Color Red Connector Color Gray Cable Jacket Material LSZH 1/3 15M Duplex MMF Cable LC/LC 62.5/125 Micron Fiber Red Jacket 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Jacket Rating OFNR Clad Diameter (microns) 125 Core Diameter (microns) 62.5 Number of Fibers 2 Cable Length (ft.) 49.2 Cable Length (m) 15.00 Cable Length (in.) 590.6 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.25 Shipping Weight (kg) 0.11 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit); 10 Gbps Attenuation @ 850NM 3.0dB/Km Insertion Loss 0.20dB CONNECTIONS Side A - Connector 1 LC DUPLEX (MALE) Side B - Connector 1 LC DUPLEX (MALE) Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N320-15M-RD 价格&库存
很抱歉,暂时无法提供与“N320-15M-RD”相匹配的价格&库存,您可以联系我们找货
