N356-10M
N356-10M
    TRIPPLITE
    DUPLEXFIBERPATCHCABLE33FT
N356-10M 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Duplex Singlemode 9/125 Fiber Patch Cable (SC/SC), 10M (33 ft.) MODEL NUMBER: N356-10M Highlights ● Premium PVC 9/125 micron singlemode patch cables ● Attenuation loss meets or exceeds the latest industry standards ● Twice the bandwidth throughput of multimode cable Package Includes 10-meter ( 33ft ) Duplex Singlemode Fiber Patch Cable, SC/SC Description Tripp Lite's 10-meter ( 33ft ), singlemode duplex fiber optic SC/SC patch cable is manufactured from 9/125 zipcord fiber. The cable has SC connectors on each end, a PVC jacket, and is FDDI and OFNR rated. Duplex singlemode fiber is most commonly used in LAN applications. Features ● Manufactured from 9/125 duplex (zipcord) fiber ● PVC jacket ● Length: 10-meter ( 33ft ) Connectors: 2 SC connectors on each end ● Insertion loss testing performed on every connector (0.2db typical) and provided with cable ● Beveled edge on ends of glass makes insertion of plug a breeze ● Fiber made from glass (not a polymer) ● Fiber optic distributed data interface (FDDI) rated ● OFNR (riser rated) Specifications OVERVIEW UPC Code 037332120342 Technology Singlemode Optical Mode OS2 PHYSICAL Cable Jacket Color Yellow 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Connector Color Blue Cable Jacket Material LSZH Cable Jacket Rating OFNR Clad Diameter (microns) 125 Core Diameter (microns) 9 Number of Fibers 2 Cable Length (ft.) 32.8 Cable Length (m) 10.00 Cable Length (in.) 393.7 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.20 Shipping Weight (kg) 0.09 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit); 10 Gbps; 40 Gbps; 100 Gbps Attenuation @ 1310NM 0.36dB/Km Attenuation @ 1550NM 0.22dB/Km Insertion Loss 0.30dB CONNECTIONS Side A - Connector 1 SC DUPLEX (MALE) Side B - Connector 1 SC DUPLEX (MALE) Endface Polish UPC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N356-10M 价格&库存
很抱歉,暂时无法提供与“N356-10M”相匹配的价格&库存,您可以联系我们找货
N356-10M
  • 1+247.640361+32.05919
  • 10+210.5071210+27.25197
  • 25+197.3289425+25.54594
  • 50+187.9123450+24.32688
  • 100+178.94983100+23.16661
  • 250+167.75887250+21.71784
  • 500+159.76379500+20.68281
库存:9
