1000 Eaton Boulevard
Cleveland, OH 44122
United States
Duplex Singlemode 9/125 Fiber Patch Cable
(LC/SC), 15M (50 ft.)
MODEL NUMBER: N366-15M
Highlights
Premium PVC 9/125 micron
singlemode patch cables
Attenuation loss meets or
exceeds the latest industry
standards
Twice the bandwidth throughput
of multimode cable
System Requirements
Any fiber optic hardware or NIC
card requiring singlemode
duplex cable with LC/SC
connectors
Package Includes
Description
Tripp Lite's 15-meter ( 50ft ) singlemode duplex fiber optic LC/SC patch cable is manufactured from 9/125
zipcord fiber. The cable has SC connectors on one end, LC connectors on the other, a PVC jacket, and is
FDDI and OFNR rated. Duplex singlemode fiber is most commonly used in LAN applications.
Features
Manufactured from 9/125 duplex (zipcord) fiber
PVC jacket
Length: 15 meters ( 50ft ). Connectors: 2 x SC; 2 x LC
Insertion loss testing performed on every connector (0.2db typical) and provided with cable
Beveled edge on ends of glass makes insertion of plug a breeze
Fiber made from glass (not a polymer)
Fiber optic distributed data interface (FDDI) rated
OFNR (riser rated)
Specifications
OVERVIEW
UPC Code
037332122759
Technology
Singlemode
Optical Mode
OS2
PHYSICAL
Cable Jacket Color
Yellow
1/3
15-meter ( 50ft ) Duplex
Singlemode Fiber Patch Cable,
LC/SC
Cleveland, OH 44122
United States
Connector Color
Blue; Blue; White
Cable Jacket Material
LSZH
Cable Jacket Rating
OFNR
Clad Diameter (microns)
125
Core Diameter (microns)
9
Number of Fibers
2
Cable Length (ft.)
49.2
Cable Length (m)
15.00
Cable Length (in.)
590.6
Minimum Bend Radius
20MM (Dynamic); 10MM (Static)
Shipping Dimensions (hwd / in.)
9.00 x 7.00 x 0.75
Shipping Dimensions (hwd / cm)
22.86 x 17.78 x 1.90
Shipping Weight (lbs.)
0.22
Shipping Weight (kg)
0.10
ENVIRONMENTAL
Operating Temperature Range
-4 to 140 °F (-20 to 60 °C)
Storage Temperature Range
Operating Humidity Range
5% to 85% RH, Non-Condensing
Storage Humidity Range
35% to 65% RH, Non-Condensing
COMMUNICATIONS
Network Compatibility
1 Gbps (Gigabit); 10 Gbps; 25 Gbps; 40 Gbps; 100 Gbps; 400 Gbps
Attenuation @ 1310NM
0.36dB/Km
Attenuation @ 1550NM
0.22dB/Km
Insertion Loss
0.30dB
CONNECTIONS
Side A - Connector 1
LC DUPLEX (MALE)
Side B - Connector 1
SC DUPLEX (MALE)
Endface Polish
UPC
FEATURES & SPECIFICATIONS
Push/Pull Tabs
No
Breakout
No
Trunk
No
2/3
Cleveland, OH 44122
United States
STANDARDS & COMPLIANCE
Product Compliance
RoHS; REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N366-15M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+285.216571+36.94552
- 10+242.4036610+31.39976
- 25+227.2308925+29.43435
- 50+216.3890650+28.02995
- 100+206.06868100+26.69310
- 250+197.51572250+25.58520
