1000 Eaton Boulevard
Cleveland, OH 44122
United States
Duplex Singlemode 9/125 Fiber Patch Cable
(LC/ST), 7M (23 ft.)
MODEL NUMBER: N368-07M
Highlights
Premium PVC 9/125 micron
singlemode patch cables - 7 m
Attenuation loss meets or
exceeds the latest industry
standards
Twice the bandwidth throughput
of multimode cable
LC/ST connectors
System Requirements
Any fiber optic hardware or NIC
card requiring singlemode
duplex cable with LC/ST
connectors
Package Includes
Features
Manufactured from 9/125 duplex (zipcord) fiber
PVC jacket
Length: 7-meters/Connectors: 2 LC and 2 ST connectors on each end
Insertion loss testing performed on every connector (0.2db typical) and provided with cable
Beveled edge on ends of glass makes insertion of plug a breeze
Fiber made from glass (not a polymer)
Fiber optic distributed data interface (FDDI) rated
OFNR (riser rated)
Specifications
OVERVIEW
UPC Code
037332138347
Technology
Singlemode
Optical Mode
OS2
PHYSICAL
Cable Jacket Color
Yellow
Connector Color
Black; Blue; White
Cable Jacket Material
LSZH
Cable Jacket Rating
OFNR
1/3
7-meter Duplex Singlemode
9/125 Fiber Patch Cable, LC/ST
Cleveland, OH 44122
United States
Clad Diameter (microns)
125
Core Diameter (microns)
9
Number of Fibers
2
Cable Length (ft.)
23
Cable Length (m)
7.01
Cable Length (in.)
275.6
Minimum Bend Radius
20MM (Dynamic); 10MM (Static)
Shipping Dimensions (hwd / in.)
0.25 x 6.40 x 6.50
Shipping Dimensions (hwd / cm)
0.64 x 16.26 x 16.51
Shipping Weight (lbs.)
0.10
Shipping Weight (kg)
0.05
ENVIRONMENTAL
Operating Temperature Range
-4 to 140 °F (-20 to 60 °C)
Storage Temperature Range
Operating Humidity Range
5% to 85% RH, Non-Condensing
Storage Humidity Range
35% to 65% RH, Non-Condensing
COMMUNICATIONS
Network Compatibility
1 Gbps (Gigabit); 10 Gbps; 25 Gbps; 40 Gbps; 100 Gbps; 400 Gbps
Attenuation @ 1310NM
0.36dB/Km
Attenuation @ 1550NM
0.22dB/Km
Insertion Loss
0.30dB
CONNECTIONS
Side A - Connector 1
LC DUPLEX (MALE)
Side B - Connector 1
ST DUPLEX (MALE)
Endface Polish
UPC
FEATURES & SPECIFICATIONS
Push/Pull Tabs
No
Breakout
No
Trunk
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; REACH
2/3
Cleveland, OH 44122
United States
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N368-07M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+242.668581+31.43407
