N836-05M
N836-05M
    TRIPPLITE
    FIBERPATCHCABLEMINLC/LCAQUA
N836-05M 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States OM3 can support 40GBASE-SR4 / 100GBASE-SR10 in applicable parallel optics networks 10Gb Duplex Multimode 50/125 OM3 LSZH Fiber Patch Cable (Mini-LC / LC) - Aqua, 5M (16 ft.) MODEL NUMBER: N836-05M Highlights ● Mini-LC to LC Fiber Patch Cable, 5 Meter ● Designed for 10-Gig Ethernet applications...OM3 Rated ● For use with networking hardware employing mini-LC SFP transceivers ● Max 10Gb distance of 300 meters @850nm ● Low-Smoke, Zero Halogen (LSZH) Aqua jacket Package Includes ● Features ● Mini-LC to LC Fiber Patch Cable, 5 Meter ● Designed for 10-Gig Ethernet applications...OM3 Rated ● For use with networking hardware employing mini-LC SFP transceivers ● Max 10Gb distance of 300 meters @850nm ● Low-Smoke, Zero Halogen (LSZH) Aqua jacket ● Use with Brocade FC8-64 and other Mini-LC SFP devices Specifications OVERVIEW UPC Code 037332165756 Technology Multimode Optical Mode OM3 PHYSICAL Cable Jacket Color Aqua Connector Color White; Beige Cable Jacket Material LSZH Cable Jacket Rating OFNR Clad Diameter (microns) 125 1/3 5M (16-ft.) 10Gb Duplex MMF 50/125 OM3 LSZH Patch Cable ( Mini-LC / LC ) - Aqua 1000 Eaton Boulevard Cleveland, OH 44122 United States Core Diameter (microns) 50 Number of Fibers 2 Cable Length (ft.) 16.4 Cable Length (m) 5.00 Cable Length (in.) 196.9 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.09 Shipping Weight (kg) 0.04 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit); 10 Gbps; 25 Gbps; 40 Gbps; 100 Gbps Attenuation @ 850NM 3.0dB/Km Insertion Loss 0.20dB CONNECTIONS Side A - Connector 1 LC DUPLEX (MALE) Side B - Connector 1 MINI LC DUPLEX (MALE) Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N836-05M 价格&库存
很抱歉,暂时无法提供与“N836-05M”相匹配的价格&库存,您可以联系我们找货
