N820-05M-T
N820-05M-T
    TRIPPLITE
    FIBERPATCHCABLELC/LCAQUA16'
N820-05M-T 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States OM3 can support 40GBASE-SR4 / 100GBASE-SR10 in applicable parallel optics networks 10Gb Duplex Multimode 50/125 OM3 LSZH Fiber Patch Cable with Push/Pull Tab Connectors, (LC/LC) - Aqua, 5M (16 ft.) MODEL NUMBER: N820-05M-T Highlights ● Push/Pull tab connectors offer maximum accessibility in high density installations; install / remove with one hand without needing additional tools ● Slim uniboot design saves space and makes cables easier to manage ● Premium-grade ceramic ferrules designed specifically for 10GbE and faster applications ● Sturdy plastic housing for longlasting durability ● Backward compatible with existing 50/125 fiber ● Max 10GbE distance of 300 meters @850nm ● Low-Smoke, Zero Halogen (LSZH) Aqua jacket Package Includes ● Features ● 5M ( 16-ft ) LC/LC, OM3 rated ● Push/Pull tab connectors offer maximum accessibility in high density installations; install / remove with one hand without needing additional tools ● Slim uniboot design saves space and makes cables easier to manage ● Premium-grade ceramic ferrule designed specifically for 10GbE and faster applications ● Sturdy plastic housing for long-lasting durability ● 10GbE speed to 300 meters @850nm ● Use with VCSEL and LED laser light sources ● High-Speed, High-Bandwidth, Low-Cost ● Backward compatible with legacy LAN's ● Ideal for Fibre Channel (SAN) applications ● IEEE 802.3ae and TIA LOMMF compliant Specifications OVERVIEW UPC Code 037332184504 Technology Multimode Optical Mode OM3 PHYSICAL 1/3 5M ( 16-ft ) Duplex Multimode 50/125 Aqua OM3 Fiber Patch Cable with Push/Pull Tabs, LC/LC 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Jacket Color Aqua Connector Color White; Aqua Cable Jacket Material LSZH Cable Jacket Rating OFNR Clad Diameter (microns) 125 Core Diameter (microns) 50 Number of Fibers 2 Cable Length (ft.) 16.4 Cable Length (m) 5.00 Cable Length (in.) 196.9 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.07 Shipping Weight (kg) 0.03 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit); 10 Gbps; 25 Gbps; 40 Gbps; 100 Gbps Attenuation @ 850NM 3.0dB/Km Insertion Loss 0.20dB CONNECTIONS Side A - Connector 1 LC DUPLEX (MALE) Side B - Connector 1 LC DUPLEX (MALE) Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs Yes Breakout No Trunk No 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N820-05M-T 价格&库存
很抱歉,暂时无法提供与“N820-05M-T”相匹配的价格&库存,您可以联系我们找货
N820-05M-T
  • 1+476.087771+61.59466
