N304-30M
N304-30M
    TRIPPLITE
    N304-30M
N304-30M 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Duplex Multimode 62.5/125 Fiber Patch Cable (SC/ST), 30M (100 ft.) MODEL NUMBER: N304-30M Highlights ● Premium PVC 62.5/125µm multimode patch cables ● Attenuation loss meets or exceeds the latest industry standards System Requirements ● Any fiber optic hardware or NIC card requiring multimode duplex cable with SC/ST connectors Package Includes ● Description Tripp Lite's 30-meter ( 100ft ) multimode duplex fiber optic SC/ST patch cable is manufactured from 62.5/125 zipcord fiber. The cable has ST to SC connectors, a PVC jacket and is FDDI and OFNR rated. Duplex multimode fiber is most commonly used in LAN applications. Features ● Manufactured from 62.5/125 duplex (zipcord) fiber ● PVC jacket ● Length: 30-meters(100ft) Connectors: 2 ST to 2 SC connectors ● Insertion loss testing performed on every connector (0.2db typical) and provided with cable ● Beveled edge on ends of glass makes insertion of plug a breeze ● Fiber made from glass (not a polymer) ● Color coded shrouds identify transmit and receive ● Fiber optic distributed data interface (FDDI) rated ● OFNR (riser rated) Specifications OVERVIEW UPC Code 037332135230 Technology Multimode Optical Mode OM1 PHYSICAL Cable Jacket Color Orange 1/3 30-meter ( 100ft ) duplex MMF cable ST/SC 62.5/125 fiber 1000 Eaton Boulevard Cleveland, OH 44122 United States Connector Color White; Black Cable Jacket Material LSZH Cable Jacket Rating OFNR Clad Diameter (microns) 125 Core Diameter (microns) 62.5 Number of Fibers 2 Cable Length (ft.) 98.4 Cable Length (m) 30.00 Cable Length (in.) 1181.1 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 12.00 x 9.00 x 2.00 Shipping Dimensions (hwd / cm) 30.48 x 22.86 x 5.08 Shipping Weight (lbs.) 0.35 Shipping Weight (kg) 0.16 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit); 10 Gbps Attenuation @ 850NM 3.0dB/Km Insertion Loss 0.20dB CONNECTIONS Side A - Connector 1 SC DUPLEX (MALE) Side B - Connector 1 ST DUPLEX (MALE) Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No STANDARDS & COMPLIANCE 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N304-30M
PDF文档提供了以下信息:
物料型号:N304-30M 器件简介:Tripp Lite的30米(100英尺)多模双工光纤SC/ST跳线,采用62.5/125 zipcord光纤制造,具有ST至SC连接器,PVC外皮,符合FDDI和OFNR标准。
引脚分配:2个ST至2个SC连接器 参数特性:使用62.5/125双工(zipcord)光纤,PVC外皮,长度30米(100英尺),插入损耗测试在每个连接器上进行(典型值0.2dB),并随电缆提供,玻璃末端斜面设计便于插入,光纤由玻璃而非聚合物制成,颜色编码的护套用于识别发送和接收,符合FDDI标准,OFNR(上升级别)。
功能详解:多模双工光纤主要用于局域网应用,支持1 Gbps和10 Gbps网络兼容性,850nm下的衰减为3.0dB/Km,插入损耗为0.20dB。
应用信息:适用于需要多模双工光纤SC/ST连接器的光纤硬件或NIC卡。
封装信息:UPC代码037332135230,技术为多模,物理特性包括橙色PVC外皮,LSZH材料,OFNR级别,包层直径125微米,芯径62.5微米,2根光纤,电缆长度30.00米,最小弯曲半径20毫米(动态)/10毫米(静态),运输尺寸12.00x9.00x2.00英寸,运输重量0.35磅,工作温度范围-4至140华氏度(-20至60摄氏度),存储温度范围-4至140华氏度(-20至60摄氏度),工作湿度范围5%至85%RH,非凝结,存储湿度范围35%至65%RH,非凝结。
产品符合RoHS和REACH标准,提供终身有限保修。
N304-30M 价格&库存
很抱歉,暂时无法提供与“N304-30M”相匹配的价格&库存,您可以联系我们找货
