N320-30M
N320-30M
    TRIPPLITE
    N320-30M
N320-30M 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Duplex Multimode 62.5/125 Fiber Patch Cable (LC/LC), 30M (100 ft.) MODEL NUMBER: N320-30M Highlights ● 30 Meter ( 100ft ) LC/LC 62.5/125 Fiber patch Cable ● Manufactured from 62.5/125 duplex (Zipcord) fiber ● Insertion loss testing performed on every connector (0.2dB typical) System Requirements ● Any fiber optic hardware or NIC card requiring multimode duplex cable with LC connectors Package Includes ● Description Tripp Lite's 30-meter ( 100ft ) multimode duplex micron fiber optic LC/LC patch cable is manufactured from 62.5/125 zipcord fiber. The cable has LC connectors on each end, a PVC jacket and is FDDI and OFNR rated. Duplex multimode fiber is most commonly used in LAN applications. Features ● Manufactured from 62.5/125 duplex (zipcord) fiber ● PVC jacket ● Length: 30 meters ( 100ft ) Connectors: LC connector on each end ● Insertion loss testing performed on every connector (0.2db typical) and provided with cable ● Beveled edge on ends of glass makes insertion of plug a breeze ● Fiber made from glass (not a polymer) ● Fiber optic distributed data interface (FDDI) rated OFNR (riser rated) Specifications OVERVIEW UPC Code 037332151674 Technology Multimode Optical Mode OM1 PHYSICAL Cable Jacket Color Orange Connector Color Gray 1/3 30 Meter ( 100ft ) Duplex MMF Cable LC/LC 62.5/125 Micron Fiber 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Jacket Material LSZH Cable Jacket Rating OFNR Clad Diameter (microns) 125 Core Diameter (microns) 62.5 Number of Fibers 2 Cable Length (ft.) 98.4 Cable Length (m) 30.00 Cable Length (in.) 1181.1 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 12.00 x 10.50 x 0.50 Shipping Dimensions (hwd / cm) 30.48 x 26.67 x 1.27 Shipping Weight (lbs.) 0.52 Shipping Weight (kg) 0.24 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit); 10 Gbps Attenuation @ 850NM 3.0dB/Km Insertion Loss 0.20dB CONNECTIONS Side A - Connector 1 LC DUPLEX (MALE) Side B - Connector 1 LC DUPLEX (MALE) Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N320-30M
PDF文档中包含的物料型号为:MAX15552,这是一款低功耗的微处理器电源管理IC。
器件简介指出其专为微处理器供电而设计,具有低静态电流、低关断电流、以及能够提供多种电压输出。
引脚分配详细列出了各个引脚的功能,包括电源引脚、控制引脚和输出引脚等。
参数特性包括输入电压范围、输出电压范围、静态电流等。
功能详解部分深入介绍了其多种电源管理功能,如电压转换、负载切换、时序控制等。
应用信息提供了器件的典型应用场景,如便携式设备、电池供电设备等。
封装信息则描述了器件的物理封装形式,便于用户在设计时选择合适的封装类型。
N320-30M 价格&库存
很抱歉,暂时无法提供与“N320-30M”相匹配的价格&库存,您可以联系我们找货
