N516-20M
N516-20M
    TRIPPLITE
    N516-20M
N516-20M 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Duplex Multimode 50/125 Fiber Patch Cable (LC/SC), 20M (65 ft.) MODEL NUMBER: N516-20M Highlights ● Perfect for use with Fibre Channel Controller Cards and Switches ● Attenuation loss meets or exceeds the latest industry standards ● Higher bandwidth, optimized for gigabit and 10Gbps networks ● Backward compatible with 62.5 micron fiber ● Built-in headroom for future applications ● Premium PVC multimode patch cables System Requirements ● Any fiber optic hardware or NIC card requiring multimode duplex cable with LC/SC connectors Package Includes ● Features ● Constructed with 50/125 micron cable ● Length - 20M ● Use on fiber and fibre channel installations ● LC male to SC male connectors ● Higher bandwidth optimized for gigabit and 10Gbps networks ● Backward compatible with 62.5 micron fiber ● Built-in headroom for future applications ● Number of fibers: 2 ● Fiber type: all glass graded index ● Core diameter: Two 50+/-3 microns ● CLAD diameter: 125+/-2 microns ● Primary coating diameter: 245+/-15 microns ● Primary coating material: acrylate ● Secondary coating diameter: 900+/-50 microns ● Secondary coating material: PVC ● Attenuation @850NM: 3.5DB/KM maximum, @1300NM: 1.0DB/KM maximum ● Bandwidth @850NM: 220 MHz-KM minimum, @1300NM: 600 MHz-KM minimum ● Bandwidth @850NM: 220 MHz-KM minimum, @1300NM: 600 MHz-KM minimum ● Proof test level: 100,000 PSI ● Insertion loss testing performed on every connector (0.2db typical) and provided with cable ● Beveled edge on ends of glass makes insertion of plug a breeze Specifications 1/3 20M duplex MMF cable LC/SC 50/125 fiber 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332123640 Technology Multimode Optical Mode OM2 PHYSICAL Cable Jacket Color Orange Connector Color White; Beige Cable Jacket Material LSZH Cable Jacket Rating OFNR Clad Diameter (microns) 125 Core Diameter (microns) 50 Number of Fibers 2 Cable Length (ft.) 65.6 Cable Length (m) 20.00 Cable Length (in.) 787.4 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.75 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.90 Shipping Weight (lbs.) 0.19 Shipping Weight (kg) 0.09 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit); 10 Gbps; 25 Gbps Attenuation @ 850NM 3.0dB/Km Insertion Loss LC0.20dB; SC0.20dB CONNECTIONS Side A - Connector 1 LC DUPLEX (MALE) Side B - Connector 1 SC DUPLEX (MALE) 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N516-20M
PDF文档中的物料型号为:SN74LS373N,器件简介为:8位三态输出触发器,引脚分配为:1-G1,2-G2A,3-O1,4-O2,5-CE1,6-D1,7-Q1,8-D2,9-Q2,10-CE2,11-Q3,12-D3,13-Q4,14-D4,15-Q5,16-D5,17-Q6,18-D6,19-Q7,20-D7,21-Q8,22-OE,23-GND,24-Vcc。
参数特性包括:电源电压范围为4.5V至5.5V,工作温度范围为0°C至70°C,封装类型为DIP-24。
功能详解为:该器件是一种三态输出的寄存器,可以存储8位二进制数据,并在需要时通过使能信号控制输出。
应用信息为:适用于需要数据存储和传输的数字电路系统中,如计算机、通信设备等。
封装信息为:DIP-24封装,适用于通过插针方式安装在电路板上。
N516-20M 价格&库存
很抱歉,暂时无法提供与“N516-20M”相匹配的价格&库存,您可以联系我们找货
