1000 Eaton Boulevard
Cleveland, OH 44122
United States
10G Duplex Multimode 50/125 OM4 LSZH Fiber
Optic Cable (LC/LC), Push/Pull Tabs, Magenta, 6
m
Highlights
Nearly 4x the bandwidth over
conventional 62.5 µm multimode
fiber
Push/pull tab connectors
install/remove with one hand
Slim, space-saving uniboot
design for neat cable
management
Premium-grade ceramic ferrules
designed for fast applications
Magenta color for easy OM4
identification
MODEL NUMBER: N821-06M-MG-T
Package Includes
Premium multimode fiber optic cabling transmits clear 10 Gb data and voice signals up to 400 m (@ 850
nm). Recommended for LANs, SANs and high-speed parallel interconnects for head-ends, central offices
and data centers.
Description
The N821-06M-MG-T 10 Gb Duplex Multimode 50/125 OM4 LSZH Fiber Patch Cable is OM4-rated for
use with 10 Gb Ethernet applications up to 400 meters (at 850 nm). Suited for LANs, SANs and highspeed parallel interconnects for head-ends, central offices and data centers, this low-cost cable provides
four times more bandwidth than conventional 62.5 µm multimode fiber and performance rivaling that of
singlemode cable.
Push/pull tab connectors are easily accessible in high-density data center applications and make the
cable easy to install and remove with one hand. Dual male LC connectors are widely compatible and
thoroughly tested to meet stringent insertion loss standards. Premium-grade ceramic ferrules are
designed specifically to handle applications of 10 Gb or higher.
Colored magenta for immediate identification as an OM4 cable, the laser-optimized multimode fiber
(LOMMF) N821-06M-MG-T is backward compatible with existing 50/125 fiber and commonly used with
vertical-cavity surface-emitting laser (VCSEL) and LED laser light sources.
The low-smoke zero-halogen (LSZH) jacket limits the amount of toxic smoke emitted in case of
combustion, making this cable perfect for poorly ventilated areas. The slim, space-saving uniboot design
is easy to manage through ceilings, walls and ducts. The sturdy plastic housing is built to last a long time.
Features
OM4-Rated for 10 Gb Ethernet Applications
● Magenta color for easy OM4 identification
Allows 10 Gb serial transmission up to 400 m (@ 850 nm)
and data centers
Provides 4x more bandwidth than conventional 62.5 µm multimode fiber
Commonly used with VCSEL and LED laser light sources
Backward compatible with existing 50/125 fiber
LC Connectors with Push/Pull Tabs
1/3
Fiber Patch Cable, 6 m (20 ft.)
Cleveland, OH 44122
United States
Push/pull tab connectors easy to install and remove with one hand
Sturdy dual LC connectors tested to meet stringent insertion loss standards
Premium Construction for Error-Free Signal Transfer
● Premium-grade ceramic ferrules for 10 GbE and faster applications
Slim, space-saving uniboot design easy to manage through ceilings, walls and ducts
Low-smoke zero-halogen jacket ideal for poorly ventilated areas
Sturdy plastic housing built to last a long time
Meets current IEEE 802.3ae and TIA LOMMF standards
Specifications
OVERVIEW
UPC Code
037332201706
Technology
Multimode
Optical Mode
OM4
PHYSICAL
Cable Jacket Color
Magenta
Connector Color
White; Aqua
Cable Jacket Material
LSZH
Cable Jacket Rating
OFNR
Clad Diameter (microns)
125
Core Diameter (microns)
50
Number of Fibers
2
Cable Length (ft.)
19.7
Cable Length (m)
6.01
Cable Length (in.)
236.2
Minimum Bend Radius
20MM (Dynamic); 10MM (Static)
Shipping Dimensions (hwd / in.)
9.00 x 7.00 x 0.50
Shipping Dimensions (hwd / cm)
22.86 x 17.78 x 1.27
Shipping Weight (lbs.)
0.07
Shipping Weight (kg)
0.03
ENVIRONMENTAL
Operating Temperature Range
-4 to 140 °F (-20 to 60 °C)
Storage Temperature Range
2/3
Cleveland, OH 44122
United States
Operating Humidity Range
5% to 85% RH, Non-Condensing
Storage Humidity Range
35% to 65% RH, Non-Condensing
COMMUNICATIONS
Network Compatibility
1 Gbps (Gigabit); 10 Gbps; 25 Gbps; 40 Gbps; 100 Gbps
Attenuation @ 850NM
3.0dB/Km
Insertion Loss
0.20dB
CONNECTIONS
Side A - Connector 1
LC DUPLEX (MALE)
Side B - Connector 1
LC DUPLEX (MALE)
Endface Polish
PC
FEATURES & SPECIFICATIONS
Push/Pull Tabs
Yes
Breakout
No
Trunk
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N821-06M-MG-T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+582.140191+75.67634
