N820-12M
N820-12M
    TRIPPLITE
    CABLEFIBEROPTICDUPLEX
N820-12M 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States OM3 can support 40GBASE-SR4 / 100GBASE-SR10 in applicable parallel optics networks 10Gb Duplex Multimode 50/125 OM3 LSZH Fiber Patch Cable (LC/LC) - Aqua, 12M (39 ft.) MODEL NUMBER: N820-12M Highlights ● Designed for 10-Gig Ethernet applications...OM3 Rated ● Backward compatible with existing 50/125 fiber ● Max 10Gb distance of 300 meters @850nm ● Low-Smoke, Zero Halogen (LSZH) Aqua jacket Package Includes ● Features ● 12M (39-ft.) LC/LC, OM3 Rated ● 10gb Ethernet speed to 300 meters @850nm ● Use with VCSEL and LED laser light sources ● High-Speed, High-Bandwidth, Low-Cost ● Backward compatible with legacy LAN's ● Ideal for Fibre Channel (SAN) applications ● IEEE 802.3ae and TIA LOMMF compliant Specifications OVERVIEW UPC Code 037332138002 Technology Multimode Optical Mode OM3 PHYSICAL Cable Jacket Color Aqua Connector Color White Cable Jacket Material LSZH Cable Jacket Rating OFNR 1/3 12M (39-ft.) Duplex Multimode 50/125 Aqua OM3 Fiber Patch Cable, LC/LC 1000 Eaton Boulevard Cleveland, OH 44122 United States Clad Diameter (microns) 125 Core Diameter (microns) 50 Number of Fibers 2 Cable Length (ft.) 39.4 Cable Length (m) 12.01 Cable Length (in.) 472.4 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.20 Shipping Weight (kg) 0.09 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit); 10 Gbps; 25 Gbps; 40 Gbps; 100 Gbps Attenuation @ 850NM 3.0dB/Km Insertion Loss 0.20dB CONNECTIONS Side A - Connector 1 LC DUPLEX (MALE) Side B - Connector 1 LC DUPLEX (MALE) Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N820-12M
物料型号为 N820-12M,是一款10Gb以太网应用设计的OM3级别多模50/125微米光纤跳线,具有12米(39英尺)长度,LC/LC连接器,水蓝色外皮。
器件简介:这款光纤跳线支持10Gb以太网速度,最大传输距离可达300米,使用VCSEL和LED激光光源,具有高速、高带宽、低成本的特点,并且与现有的50/125微米光纤和传统局域网络向后兼容。
引脚分配:跳线两端均为LC DUPLEX(MALE)连接器。
参数特性:光纤跳线具有125微米包层直径和50微米芯径,包含2根光纤,长度为39.4英尺(12.01米),最小弯曲半径为20毫米(动态)和10毫米(静态),外皮材料为LSZH,符合OFNR等级。
功能详解:该光纤跳线适用于1Gbps、10Gbps、25Gbps、40Gbps和100Gbps网络,插入损耗为0.20dB,符合IEEE 802.3ae和TIA LOMMF标准。
应用信息:理想用于光纤通道(SAN)应用,支持40GBASE-SR4/100GBASE-SR10在适用的并行光学网络中。
封装信息:产品采用水蓝色低烟无卤(LSZH)外皮,白色连接器,提供12米(39英尺)长度,具有环保和安全特性。
此外,产品符合RoHS和REACH标准,享有全球范围内的有限终身保修。
N820-12M 价格&库存
很抱歉,暂时无法提供与“N820-12M”相匹配的价格&库存,您可以联系我们找货
