N838-10M
N838-10M
    TRIPPLITE
    FIBERCABLEMINI-LCMINI-LC33'
N838-10M 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States OM3 can support 40GBASE-SR4 / 100GBASE-SR10 in applicable parallel optics networks 10Gb Duplex Multimode 50/125 OM3 LSZH Fiber Patch Cable (Mini-LC / Mini-LC) - Aqua, 10M (33 ft.) Highlights ● Mini-LC to Mini-LC Fiber Patch Cable, 10 Meter ● Designed for 10-Gig Ethernet applications...OM3 Rated ● For use with networking hardware employing mini-LC SFP transceivers ● Max 10Gb distance of 300 meters @850nm ● Low-Smoke, Zero Halogen (LSZH) Aqua jacket MODEL NUMBER: N838-10M Package Includes ● Features ● Mini-LC to Mini-LC Fiber Patch Cable, 10 Meter ● Designed for 10-Gig Ethernet applications...OM3 Rated ● For use with networking hardware employing mini-LC SFP transceivers ● Max 10Gb distance of 300 meters @850nm ● Low-Smoke, Zero Halogen (LSZH) Aqua jacket ● Use with Brocade FC8-64 and other Mini-LC SFP devices Specifications OVERVIEW UPC Code 037332165879 Technology Multimode Optical Mode OM3 PHYSICAL Cable Jacket Color Aqua Connector Color White; Black; Beige Cable Jacket Material LSZH Cable Jacket Rating OFNR 1/3 10M (33-ft.) 10Gb Duplex MMF 50/125 OM3 LSZH Patch cable ( Mini-LC to Mini-LC ) - Aqua 1000 Eaton Boulevard Cleveland, OH 44122 United States Clad Diameter (microns) 125 Core Diameter (microns) 50 Number of Fibers 2 Cable Length (ft.) 32.8 Cable Length (m) 10.00 Cable Length (in.) 393.7 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 0.25 x 5.30 x 6.30 Shipping Dimensions (hwd / cm) 0.64 x 13.46 x 16.00 Shipping Weight (lbs.) 0.20 Shipping Weight (kg) 0.09 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit); 10 Gbps; 40 Gbps; 100 Gbps Attenuation @ 850NM 3.0dB/Km Insertion Loss 0.20dB CONNECTIONS Side A - Connector 1 MINI LC DUPLEX (MALE) Side B - Connector 1 MINI LC DUPLEX (MALE) Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N838-10M 价格&库存
很抱歉,暂时无法提供与“N838-10M”相匹配的价格&库存,您可以联系我们找货
