N320-46M
N320-46M
    TRIPPLITE
    N320-46M
N320-46M 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Duplex Multimode 62.5/125 Fiber Patch Cable (LC/LC), 46M (150 ft.) MODEL NUMBER: N320-46M Highlights ● Manufactured from 62.5/125 duplex (Zipcord) fiber ● Insertion loss testing performed on every connector (0.2dB typical) System Requirements ● Any fiber optic hardware or NIC card requiring multimode duplex cable with LC connectors Package Includes ● Description Tripp Lite's 46-meter ( 150ft ) multimode duplex micron fiber optic LC/LC patch cable is manufactured from 62.5/125 zipcord fiber. The cable has LC connectors on each end, a PVC jacket and is FDDI and OFNR rated. Duplex multimode fiber is most commonly used in LAN applications. Features ● Manufactured from 62.5/125 duplex (zipcord) fiber ● PVC jacket ● Length: 46 meters ( 150ft ) Connectors: LC connector on each end ● Insertion loss testing performed on every connector (0.2db typical) and provided with cable ● Beveled edge on ends of glass makes insertion of plug a breeze ● Fiber made from glass (not a polymer) ● Fiber optic distributed data interface (FDDI) rated ● OFNR (riser rated) Specifications OVERVIEW UPC Code 037332134905 Technology Multimode Optical Mode OM1 PHYSICAL Cable Jacket Color Orange 1/3 46 Meter ( 150ft ) Duplex MMF Cable LC/LC 62.5/125 Micron Fiber 1000 Eaton Boulevard Cleveland, OH 44122 United States Connector Color Gray Cable Jacket Material LSZH Cable Jacket Rating OFNR Clad Diameter (microns) 125 Core Diameter (microns) 62.5 Number of Fibers 2 Cable Length (ft.) 150.9 Cable Length (m) 46.01 Cable Length (in.) 1811 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 12.00 x 10.50 x 0.50 Shipping Dimensions (hwd / cm) 30.48 x 26.67 x 1.27 Shipping Weight (lbs.) 0.78 Shipping Weight (kg) 0.35 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit); 10 Gbps Attenuation @ 850NM 3.0dB/Km Insertion Loss 0.20dB CONNECTIONS Side A - Connector 1 LC DUPLEX (MALE) Side B - Connector 1 LC DUPLEX (MALE) Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No STANDARDS & COMPLIANCE 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N320-46M 价格&库存
很抱歉,暂时无法提供与“N320-46M”相匹配的价格&库存,您可以联系我们找货
