1000 Eaton Boulevard
Cleveland, OH 44122
United States
Fiber Optic Mode Conditioning Patch Cable ( SC /
Mode Conditioning to ST ), 3M (10 ft.)
MODEL NUMBER: N420-03M
Features
SC / Mode Conditioning to ST Duplex Fiber Patch Cable - 3 Meter
62.5/125 and 9/125
Use Singlemode Transceivers on Multimode Fiber Backbones
Offsets the Singlemode Laser launch from the center of a Multimode fiber
Available in a variety of connector combinations
Specifications
OVERVIEW
UPC Code
037332119193
Optical Mode
OM1
PHYSICAL
Cable Jacket Color
Orange; Yellow
Connector Color
Blue; Gray; Black; Red
Cable Jacket Material
PVC
Cable Jacket Rating
OFNR
Clad Diameter (microns)
125
Core Diameter (microns)
62.5
Number of Fibers
2
Cable Length (ft.)
9.8
1/3
Highlights
3 Meter SC/Mode Conditioning
to ST Fiber Patch Cable
62.5/125 and 9/125
Run 1000Base-LX Gigabit
Ethernet over MMF by offsetting
signal loss
IEEE 802.3z Gigabit Ethernet
Compliant
Cleveland, OH 44122
United States
Cable Length (m)
2.99
Cable Length (in.)
118.1
Minimum Bend Radius
20MM (Dynamic); 10MM (Static)
Shipping Dimensions (hwd / in.)
0.25 x 5.90 x 8.50
Shipping Dimensions (hwd / cm)
0.64 x 14.99 x 21.59
Shipping Weight (lbs.)
0.10
Shipping Weight (kg)
0.05
ENVIRONMENTAL
Operating Temperature Range
-4 to 140 °F (-20 to 60 °C)
Storage Temperature Range
Operating Humidity Range
5% to 85% RH, Non-Condensing
Storage Humidity Range
35% to 65% RH, Non-Condensing
COMMUNICATIONS
Attenuation @ 850NM
3.0dB/Km
Insertion Loss
MM TO MM0.20dB;MM TO SM0.30dB
CONNECTIONS
Side A - Connector 1
SC DUPLEX (MALE)
Side B - Connector 1
ST DUPLEX (MALE)
Endface Polish
PC
FEATURES & SPECIFICATIONS
Push/Pull Tabs
No
Breakout
No
Trunk
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
2/3
Cleveland, OH 44122
United States
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N420-03M”相匹配的价格&库存,您可以联系我们找货
