N422-01M
N422-01M
    TRIPPLITE
    N422-01M
N422-01M 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Fiber Optic Mode Conditioning Patch Cable (ST/LC), 1M (3 ft.) MODEL NUMBER: N422-01M Highlights ● 1 Meter LC/ST Mode Conditioning Cable ● 62.5/125 and 9/125 ● Run 1000Base-LX Gigabit Ethernet over MMF by offsetting signal loss ● IEEE 802.3z Gigabit Ethernet Compliant Package Includes ● Features ● Use Singlemode Transceivers on Multimode Fiber Backbones ● 62.5/125 and 9/125 ● Offsets the Singlemode Laser/LED launch from the center of a Multimode fiber ● Available in a variety of connector combinations Specifications OVERVIEW UPC Code 037332129482 Optical Mode OM1 PHYSICAL Cable Jacket Color Orange; Yellow Connector Color Blue; Gray; Black Cable Jacket Material PVC Cable Jacket Rating OFNR Clad Diameter (microns) 125 Core Diameter (microns) 62.5 Number of Fibers 2 Cable Length (ft.) 3.3 1/3 1 Meter LC/ST Mode Conditioning Cable 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Length (m) 1.01 Cable Length (in.) 39.4 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.07 Shipping Weight (kg) 0.03 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Attenuation @ 850NM 3.0dB/Km Insertion Loss MM TO MM0.20dB;MM TO SM0.30dB CONNECTIONS Side A - Connector 1 LC DUPLEX (MALE) Side B - Connector 1 ST DUPLEX (MALE) Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N422-01M 价格&库存
很抱歉,暂时无法提供与“N422-01M”相匹配的价格&库存,您可以联系我们找货
