N520-50M
N520-50M
    TRIPPLITE
    N520-50M
N520-50M 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Duplex Multimode 50/125 Fiber Patch Cable (LC/LC), 50M (164 ft.) MODEL NUMBER: N520-50M Highlights ● Premium PVC multimode patch cables ● Attenuation loss meets or exceeds the latest industry standards ● Higher bandwidth optimized for gigabit and 10Gbps networks ● Backward compatible with 62.5 micron fiber ● Built-in headroom for future applications System Requirements ● Any fiber optic hardware or NIC card requiring multimode duplex cable with LC/LC connectors Package Includes ● Features ● Constructed with 50/125 micron cable ● Length - 50M ● Use on fiber and fibre channel installations ● LC male to LC male connectors ● Higher bandwidth optimized for gigabit and 10Gbps networks ● Backward compatible with 62.5 micron fiber ● Built-in headroom for future applications ● Number of fibers: 2 ● Fiber type: all glass graded index ● Core diameter: two 50+/-3 microns ● CLAD diameter: 125+/-2 microns ● Primary coating diameter: 245+/-15 microns ● Primary coating material: acrylate ● Secondary coating diameter: 900+/-50 microns ● Secondary coating material: PVC ● Attenuation @850NM: 3.5DB/KM maximum, @1300NM: 1.0DB/KM maximum ● Bandwidth @850NM: 220 MHz-KM minimum, @1300NM: 600 MHz-KM minimum ● Numeric aperture: .275 nominal ● Proof test level: 100,000 PSI ● Insertion loss testing performed on every connector (0.2db typical) and provided with cable ● Beveled edge on ends of glass makes insertion of plug a breeze Specifications 1/3 50M Duplex MMF Cable LC/LC 50/125 Fiber 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332119476 Technology Multimode Optical Mode OM2 PHYSICAL Cable Jacket Color Orange Connector Color Gray Cable Jacket Material LSZH Cable Jacket Rating OFNR Clad Diameter (microns) 125 Core Diameter (microns) 50 Number of Fibers 2 Cable Length (ft.) 164 Cable Length (m) 50.00 Cable Length (in.) 1968.5 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 2.00 x 7.50 x 8.00 Shipping Dimensions (hwd / cm) 5.08 x 19.05 x 20.32 Shipping Weight (lbs.) 0.80 Shipping Weight (kg) 0.36 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit); 10 Gbps; 25 Gbps Attenuation @ 850NM 3.0dB/Km Insertion Loss 0.20dB CONNECTIONS Side A - Connector 1 LC DUPLEX (MALE) Side B - Connector 1 LC DUPLEX (MALE) 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N520-50M 价格&库存
很抱歉,暂时无法提供与“N520-50M”相匹配的价格&库存,您可以联系我们找货
