1000 Eaton Boulevard
Cleveland, OH 44122
United States
Duplex Multimode 62.5/125 Fiber Patch Cable
(LC/LC), 123M (405 ft.)
MODEL NUMBER: N320-405
Highlights
Manufactured from 62.5/125
duplex (Zipcord) fiber
Insertion loss testing performed
on every connector (0.2dB
typical)
System Requirements
Any fiber optic hardware or NIC
card requiring multimode duplex
cable with LC connectors
Package Includes
Description
Tripp Lite's 405-ft. (123.44 m) multimode duplex micron fiber optic LC/LC patch cable is manufactured
from 62.5/125 zipcord fiber. The cable has LC connectors on each end, a PVC jacket and is FDDI and
OFNR rated. Duplex multimode fiber is most commonly used in LAN applications.
Features
Manufactured from 62.5/125 duplex (zipcord) fiber
PVC jacket
Length: 405-ft. (123.44 m)
Connectors: LC connector on each end
Insertion loss testing performed on every connector (0.2db typical) and provided with cable
Beveled edge on ends of glass makes insertion of plug a breeze
Fiber made from glass (not a polymer)
Fiber optic distributed data interface (FDDI) rated
OFNR (riser rated)
Specifications
OVERVIEW
UPC Code
037332140463
Technology
Multimode
Optical Mode
OM1
PHYSICAL
Cable Jacket Color
Orange
1/3
405-ft. (123.44 m) LC/LC Duplex
MMF 62.5/125 Fiber Patch
Cable
Cleveland, OH 44122
United States
Connector Color
Gray
Cable Jacket Material
LSZH
Cable Jacket Rating
OFNR
Clad Diameter (microns)
125
Core Diameter (microns)
62.5
Number of Fibers
2
Cable Length (ft.)
405
Cable Length (m)
123.48
Cable Length (in.)
4860
Minimum Bend Radius
20MM (Dynamic); 10MM (Static)
Shipping Dimensions (hwd / in.)
10.10 x 4.70 x 10.30
Shipping Dimensions (hwd / cm)
25.65 x 11.94 x 26.16
Shipping Weight (lbs.)
2.90
Shipping Weight (kg)
1.32
ENVIRONMENTAL
Operating Temperature Range
-4 to 140 °F (-20 to 60 °C)
Storage Temperature Range
Operating Humidity Range
5% to 85% RH, Non-Condensing
Storage Humidity Range
35% to 65% RH, Non-Condensing
COMMUNICATIONS
Network Compatibility
1 Gbps (Gigabit); 10 Gbps
Attenuation @ 850NM
3.0dB/Km
Insertion Loss
0.20dB
CONNECTIONS
Side A - Connector 1
LC DUPLEX (MALE)
Side B - Connector 1
LC DUPLEX (MALE)
Endface Polish
PC
FEATURES & SPECIFICATIONS
Push/Pull Tabs
No
Breakout
No
Trunk
No
STANDARDS & COMPLIANCE
2/3
Cleveland, OH 44122
United States
Product Compliance
RoHS; REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N320-405”相匹配的价格&库存,您可以联系我们找货
