N844-02M-8LC-P
N844-02M-8LC-P
    TRIPPLITE
    N844-02M-8LC-P
N844-02M-8LC-P 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States OM3 can support 40GBASE-SR4 / 100GBASE-SR10 in applicable parallel optics networks MTP/MPO Fan-Out Cable, MTP/MPO to 4xLC, 40GbE, 40GBASE-SR4, OM3 Plenum-Rated Aqua, 2M (6 ft.) Highlights ● MTP / MPO to 8 x LC Fan-out Cable ● OM3, 40GbE rated, 40GBASESR4 ● 50/125 Multimode MODEL NUMBER: N844-02M-8LC-P Package Includes ● Features ● MTP / MPO to 8 x LC, 2 Meter Fan-out Cable ● 40GbE rated OM3 50/125 Multimode ● Plenum rated jacket Specifications OVERVIEW UPC Code 037332173768 Technology Multimode Optical Mode OM3 PHYSICAL Cable Jacket Color Aqua Connector Color Aqua; Black; Gray Cable Jacket Material PVC Cable Jacket Rating OFNP Clad Diameter (microns) 125 Core Diameter (microns) 50 Number of Fibers 8 1/3 2M (6-ft.) MTP / MPO Fan-out Cable, MTP/MPO to 8 x LC, 40GbE OM3 Plenum 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Length (ft.) 6.6 Cable Length (m) 2.01 Cable Length (in.) 78.7 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 0.25 x 4.90 x 6.00 Shipping Dimensions (hwd / cm) 0.64 x 12.45 x 15.24 Shipping Weight (lbs.) 0.10 Shipping Weight (kg) 0.05 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 40 Gbps; 100 Gbps; 400 Gbps Attenuation @ 850NM 3.0dB/Km Insertion Loss 0.35dB CONNECTIONS Side A - Connector 1 12-STRAND MTP/MPO (FEMALE) Side B - Connector 1 (8) LC DUPLEX (MALE) Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout Yes Trunk Yes STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N844-02M-8LC-P 价格&库存
很抱歉,暂时无法提供与“N844-02M-8LC-P”相匹配的价格&库存,您可以联系我们找货
