N845-01M-12-MG
N845-01M-12-MG
    TRIPPLITE
    MTP/MPOMULTIMODEPATCHCABLE,1
N845-01M-12-MG 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 100G MTP/MPO Multimode OM4 Plenum-Rated Fiber Optic Cable (F/F), 12 Fiber, 40/100GBASESR4, Push/Pull Tabs, Magenta, 1 m Highlights ● Push/pull tab connectors install/remove with one hand ● 12-fiber MTP/MPO connectors with 12x density of SC connectors ● 100% tested for low insertion loss and back reflection ● 50/125 OM4-rated multimode fiber ● Base-8 Fiber compatible with both QSFP+ 40GBASE-SR4 and QSFP28 100GBASE-SR4 connections ● Magenta color for easy OM4 identification MODEL NUMBER: N845-01M-12-MG Package Includes ● Premium multimode fiber optic cabling for transmitting 40/100 Gb data and voice signals over short distances. Designed for high-density connections between network equipment in telecom rooms and data centers. Description The one-meter N845-01M-12-MG MTP/MPO Multimode Patch Cable supports 40/100 Gb Ethernet speeds and is designed for high-density connections between network equipment in telecommunication rooms and data centers. With two female MTP/MPO connectors, this OM4-rated multimode fiber optic cable is recommended for high-density fiber patching between data center MDFs (main distribution frames) and IDF (intermediate distribution frames). It’s colored magenta for instant identification as an OM4 cable. Base-8 Fiber compatible with both QSFP+ 40GBASE-SR4 and QSFP28 100GBASE-SR4 connections. The 12-fiber MTP/MPO connectors are about the same size as SC connectors, but are 12 times denser, freeing up circuit card and rack space for other cables. The cable is tested for low insertion loss and back reflection on every connector and attenuation loss that meets or exceeds current standards. Push/pull tab connectors are easily accessible in high-density data center applications and make the cable easy to install and remove with one hand. The plenum-rated jacket is perfect for connecting high-speed network components in ceilings, walls and ducts. Features OM4-Rated for 40/100 Gb Ethernet Applications ● Designed to extend high-density connections between network equipment in telecommunication rooms and data centers ● Base-8 Fiber compatible with both QSFP+ 40GBASE-SR4 and QSFP28 100GBASE-SR4 connections ● Backward compatible with existing 50/125 fiber ● Magenta-colored for identification as an OM4 cable MTP/MPO Connectors with Push/Pull Tabs ● 12-fiber female connectors 12 times denser than SC connectors ● Push/pull tab connectors easy to install and remove with one hand ● 100% tested for low insertion loss and back reflection 1/3 N845-01M-12-MG MTP/MPO Multimode Patch Cable, Magenta, 1 m 1000 Eaton Boulevard Cleveland, OH 44122 United States Error-Free Signal Transfer ● 50/125 duplex glass fiber construction ● Plenum-rated jacket perfect for ceilings, walls and ducts Specifications OVERVIEW UPC Code 037332200266 Technology Multimode Optical Mode OM4 PHYSICAL Cable Jacket Color Magenta Connector Color Magenta; Black Cable Jacket Material PVC Cable Jacket Rating OFNP Clad Diameter (microns) 125 Core Diameter (microns) 50 Number of Fibers 12 Cable Length (ft.) 3.3 Cable Length (m) 1.01 Cable Length (in.) 39.4 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 0.50 x 7.00 x 9.00 Shipping Dimensions (hwd / cm) 1.27 x 17.78 x 22.86 Shipping Weight (lbs.) 0.04 Shipping Weight (kg) 0.02 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 40 Gbps; 100 Gbps; 400 Gbps 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Attenuation @ 850NM 3.0dB/Km Insertion Loss 0.35dB CONNECTIONS Side A - Connector 1 12-STRAND MTP/MPO (FEMALE) Side B - Connector 1 12-STRAND MTP/MPO (FEMALE) Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs Yes Breakout No Trunk No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N845-01M-12-MG 价格&库存
很抱歉,暂时无法提供与“N845-01M-12-MG”相匹配的价格&库存,您可以联系我们找货
