1000 Eaton Boulevard
Cleveland, OH 44122
United States
OM3 can support 40GBASE-SR4 / 100GBASE-SR10 in applicable parallel optics networks
MTP/MPO Fan-out Cable with Push/Pull Tab
Connectors, MTP/MPO to 4xLC, 40GbE,
40GBASE-SR4,OM3 Plenum-rated - Aqua, 1M
(3.28 ft.)
MODEL NUMBER: N844-01M-8LC-PT
Highlights
MTP / MPO to 8 x LC Fan-out
Cable
Push/Pull tab connectors offer
maximum accessibility in high
density installations; install /
remove with one hand without
needing additional tools
Slim uniboot design saves
space and makes cables easier
to manage
Premium-grade ceramic ferrule
designed specifically for 10GbE
and faster applications
Sturdy plastic housing for longlasting durability
OM3, 40GbE rated, 40GBASESR4
Backward compatible with
existing 50/125 fiber
Plenum rated jacket
Package Includes
Features
MTP / MPO to 8 x LC Fan-out Cable
Push/Pull tab connectors offer maximum accessibility in high density installations; install / remove with
one hand without needing additional tools
Slim uniboot design saves space and makes cables easier to manage
Premium-grade ceramic ferrule designed specifically for 10GbE and faster applications
Sturdy plastic housing for long-lasting durability
OM3, 40GbE rated, 40GBASE-SR4
Backward compatible with existing 50/125 fiber
Plenum rated jacket
Specifications
OVERVIEW
UPC Code
037332185259
Technology
Multimode
Optical Mode
OM3
PHYSICAL
Cable Jacket Color
Aqua
1/3
1M (3.28-ft.) MTP / MPO Fanout Cable, MTP/MPO to 8 x LC,
40GbE OM3 Plenum
Cleveland, OH 44122
United States
Connector Color
Aqua; Black; Aqua
Cable Jacket Material
PVC
Cable Jacket Rating
OFNP
Clad Diameter (microns)
125
Core Diameter (microns)
50
Number of Fibers
8
Cable Length (ft.)
3.3
Cable Length (m)
1.01
Cable Length (in.)
39.4
Minimum Bend Radius
20MM (Dynamic); 10MM (Static)
Shipping Dimensions (hwd / in.)
9.00 x 7.00 x 0.50
Shipping Dimensions (hwd / cm)
22.86 x 17.78 x 1.27
Shipping Weight (lbs.)
0.14
Shipping Weight (kg)
0.06
ENVIRONMENTAL
Operating Temperature Range
-4 to 140 °F (-20 to 60 °C)
Storage Temperature Range
Operating Humidity Range
5% to 85% RH, Non-Condensing
Storage Humidity Range
35% to 65% RH, Non-Condensing
COMMUNICATIONS
Network Compatibility
40 Gbps; 100 Gbps; 400 Gbps
Attenuation @ 850NM
3.0dB/Km
Insertion Loss
0.35dB
CONNECTIONS
Side A - Connector 1
12-STRAND MTP/MPO (FEMALE)
Side B - Connector 1
(8) LC DUPLEX (MALE)
Endface Polish
PC
FEATURES & SPECIFICATIONS
Push/Pull Tabs
Yes
Breakout
Yes
Trunk
Yes
STANDARDS & COMPLIANCE
2/3
Cleveland, OH 44122
United States
Product Compliance
RoHS; REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N844-01M-8LC-PT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1972.698141+256.44438
