1000 Eaton Boulevard
Cleveland, OH 44122
United States
40G MTP/MPO to 4xLC Fan-Out OM4 PlenumRated Fiber Optic Cable, 40GBASE-SR4,
Push/Pull Tabs, Magenta, 1 m
Highlights
Push/pull tab connectors
install/remove with one hand
Plenum-rated jacket for
connecting in ceilings, walls and
ducts
Magenta color for easy OM4
identification
Base-8 Fiber compatible with
both QSFP+ 40GBASE-SR4
and QSFP28 100GBASE-SR4
connections
Slim, space-saving uniboot
design for neat cable
management
Premium-grade ceramic ferrule
designed for fast applications
MODEL NUMBER: N845-01M-8L-MG
Package Includes
Connects 4 10Gb duplex LC devices to a 40Gb MTP port on a network switch. Designed for high-density
connections between 40GBASE-SR4 network equipment.
Description
The one-meter N845-01M-8L-MG MTP/MPO to 8xLC Fan-Out Patch Cable supports 40 Gb Ethernet
speeds and is designed for high-density connections between 40GBASE-SR4 network equipment. With
one male MTP/MPO and eight male LC connectors, this OM4-rated multimode fiber optic fan-out cable
supports various multi- and single-fiber connections. It fully transmits 40GBASE-SR with four fibers
transmitting at 10 Gbps in each direction. Base-8 Fiber compatible with both QSFP+ 40GBASE-SR4 and
QSFP28 100GBASE-SR4 connections.
Push/pull tab connectors are easily accessible in high-density data center applications and make the
cable easy to install and remove with one hand. The magenta-colored N845-01M-8L-MG features a
premium-grade ceramic ferrule for 10 GbE and faster applications. The slim, space-saving uniboot design
makes cable easier to manage. The plenum-rated jacket is perfect for connecting high-speed network
components in ceilings, walls and ducts. The sturdy plastic housing is built to last a long time.
Features
OM4-Rated for 40 Gb Ethernet Applications
● Connects 4 10Gb duplex LC devices to a 40Gb MTP port on a network switch
Designed for high-density connections between 40GBASE-SR4 network equipment
Base-8 Fiber compatible with both QSFP+ 40GBASE-SR4 and QSFP28 100GBASE-SR4 connections
Multimode fiber optic fan-out cable supports various multi- and single-fiber connections
Fully transmits 40GBASE-SR with four fibers transmitting at 10 Gbps in each direction
Magenta-colored for identification as an OM4 cable
MTP/MPO and LC Connectors with Push/Pull Tabs
● 1 male MTP/MPO and 8 male LC connectors
Push/pull tab connectors easy to install and remove with one hand
Error-Free Signal Transfer
1/3
8xLC Fan-Out Patch Cable,
Magenta, 1 m
Cleveland, OH 44122
United States
Premium-grade ceramic ferrule for 10 GbE and faster applications
Slim, space-saving uniboot design makes cable easier to manage
Plenum-rated jacket for connecting in ceilings, walls and ducts
Sturdy plastic housing built to last a long time
Specifications
OVERVIEW
UPC Code
037332200044
Technology
Multimode
Optical Mode
OM4
PHYSICAL
Cable Jacket Color
Magenta
Connector Color
Aqua; Magenta; Black
Cable Jacket Material
PVC
Cable Jacket Rating
OFNP
Clad Diameter (microns)
125
Core Diameter (microns)
50
Number of Fibers
8
Cable Length (ft.)
3.3
Cable Length (m)
1.01
Cable Length (in.)
39.4
Minimum Bend Radius
20MM (Dynamic); 10MM (Static)
Shipping Dimensions (hwd / in.)
0.50 x 7.00 x 9.00
Shipping Dimensions (hwd / cm)
1.27 x 17.78 x 22.86
Shipping Weight (lbs.)
0.09
Shipping Weight (kg)
0.04
ENVIRONMENTAL
Operating Temperature Range
-4 to 140 °F (-20 to 60 °C)
Storage Temperature Range
Operating Humidity Range
5% to 85% RH, Non-Condensing
Storage Humidity Range
35% to 65% RH, Non-Condensing
COMMUNICATIONS
Network Compatibility
40 Gbps; 100 Gbps; 400 Gbps
2/3
Cleveland, OH 44122
United States
Attenuation @ 850NM
3.0dB/Km
Insertion Loss
0.35dB
CONNECTIONS
Side A - Connector 1
12-STRAND MTP/MPO (FEMALE)
Side B - Connector 1
(8) LC DUPLEX (MALE)
Endface Polish
PC
FEATURES & SPECIFICATIONS
Push/Pull Tabs
Yes
Breakout
Yes
Trunk
Yes
STANDARDS & COMPLIANCE
Product Compliance
RoHS; REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N845-01M-8L-MG”相匹配的价格&库存,您可以联系我们找货
