N845-02M-8L-MG
N845-02M-8L-MG
    TRIPPLITE
    N845-02M-8L-MG
N845-02M-8L-MG 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 40G MTP/MPO to 4xLC Fan-Out OM4 PlenumRated Fiber Optic Cable, 40GBASE-SR4, Push/Pull Tabs, Magenta, 2 m Highlights ● Push/pull tab connectors install/remove with one hand ● Plenum-rated jacket for connecting in ceilings, walls and ducts ● Base-8 Fiber compatible with both QSFP+ 40GBASE-SR4 and QSFP28 100GBASE-SR4 connections ● Magenta color for easy OM4 identification ● Slim, space-saving uniboot design for neat cable management ● Premium-grade ceramic ferrule designed for fast applications MODEL NUMBER: N845-02M-8L-MG Package Includes ● Connects 4 10Gb duplex LC devices to a 40Gb MTP port on a network switch. Designed for high-density connections between 40GBASE-SR4 network equipment. Description The two-meter N845-02M-8L-MG MTP/MPO to 8xLC Fan-Out Patch Cable supports 40 Gb Ethernet speeds and is designed for high-density connections between 40GBASE-SR4 network equipment. With one female MTP/MPO and eight male LC connectors, this OM4-rated multimode fiber optic fan-out cable supports various multi- and single-fiber connections. It fully transmits 40GBASE-SR with four fibers transmitting at 10 Gbps in each direction. Base-8 Fiber compatible with both QSFP+ 40GBASE-SR4 and QSFP28 100GBASE-SR4 connections. Push/pull tab connectors are easily accessible in high-density data center applications and make the cable easy to install and remove with one hand. The magenta-colored N845-02M-8L-MG features a premium-grade ceramic ferrule for 10 GbE and faster applications. The slim, space-saving uniboot design makes cable easier to manage. The plenum-rated jacket is perfect for connecting high-speed network components in ceilings, walls and ducts. The sturdy plastic housing is built to last a long time. Features OM4-Rated for 40 Gb Ethernet Applications ● Connects 4 10Gb duplex LC devices to a 40Gb MTP port on a network switch ● Designed for high-density connections between 40GBASE-SR4 network equipment ● Base-8 Fiber compatible with both QSFP+ 40GBASE-SR4 and QSFP28 100GBASE-SR4 connections ● Multimode fiber optic fan-out cable supports various multi- and single-fiber connections. ● Fully transmits 40GBASE-SR with four fibers transmitting at 10 Gbps in each direction ● Magenta-colored for identification as an OM4 cable MTP/MPO and LC Connectors with Push/Pull Tabs ● 1 female MTP/MPO and 8 male LC connectors ● Push/pull tab connectors easy to install and remove with one hand Error-Free Signal Transfer ● Premium-grade ceramic ferrule for 10 GbE and faster applications ● Slim, space-saving uniboot design makes cable easier to manage 1/3 N845-02M-8L-MG MTP/MPO to 8xLC Fan-Out Patch Cable, Magenta, 2 m 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Plenum-rated jacket for connecting in ceilings, walls and ducts ● Sturdy plastic housing built to last a long time Specifications OVERVIEW UPC Code 037332200051 Technology Multimode Optical Mode OM4 PHYSICAL Cable Jacket Color Magenta Connector Color Aqua; Magenta; Black Cable Jacket Material PVC Cable Jacket Rating OFNP Clad Diameter (microns) 125 Core Diameter (microns) 50 Number of Fibers 8 Cable Length (ft.) 6.6 Cable Length (m) 2.01 Cable Length (in.) 78.7 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.15 Shipping Weight (kg) 0.07 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 40 Gbps; 100 Gbps; 400 Gbps Attenuation @ 850NM 3.0dB/Km 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Insertion Loss 0.35dB CONNECTIONS Side A - Connector 1 12-STRAND MTP/MPO (FEMALE) Side B - Connector 1 (8) LC DUPLEX (MALE) Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs Yes Breakout Yes Trunk Yes STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N845-02M-8L-MG 价格&库存
很抱歉,暂时无法提供与“N845-02M-8L-MG”相匹配的价格&库存,您可以联系我们找货
