1000 Eaton Boulevard
Cleveland, OH 44122
United States
40G MTP/MPO to 4xLC Fan-Out OM4 PlenumRated Fiber Optic Cable, 40GBASE-SR4,
Push/Pull Tabs, Magenta, 3 m
Highlights
Push/pull tab connectors
install/remove with one hand
Plenum-rated jacket for
connecting in ceilings, walls and
ducts
Base-8 Fiber compatible with
both QSFP+ 40GBASE-SR4
and QSFP28 100GBASE-SR4
connections
Magenta color for easy OM4
identification
Slim, space-saving uniboot
design for neat cable
management
Premium-grade ceramic ferrule
designed for fast applications
MODEL NUMBER: N845-03M-8L-MG
Package Includes
Connects 4 10Gb duplex LC devices to a 40Gb MTP port on a network switch. Designed for high-density
connections between 40GBASE-SR4 network equipment.
Description
The three-meter N845-03M-8L-MG MTP/MPO to 8xLC Fan-Out Patch Cable supports 40 Gb Ethernet
speeds and is designed for high-density connections between 40GBASE-SR4 network equipment. With
one male MTP/MPO and eight male LC connectors, this OM4-rated multimode fiber optic fan-out cable
supports various multi- and single-fiber connections. It fully transmits 40GBASE-SR with four fibers
transmitting at 10 Gbps in each direction. Base-8 Fiber compatible with both QSFP+ 40GBASE-SR4 and
QSFP28 100GBASE-SR4 connections.
Push/pull tab connectors are easily accessible in high-density data center applications and make the
cable easy to install and remove with one hand. The magenta-colored N845-03M-8L-MG features a
premium-grade ceramic ferrule for 10 GbE and faster applications. The slim, space-saving uniboot design
makes cable easier to manage. The plenum-rated jacket is perfect for connecting high-speed network
components in ceilings, walls and ducts. The sturdy plastic housing is built to last a long time.
Features
OM4-Rated for 40 Gb Ethernet Applications
● Connects 4 10Gb duplex LC devices to a 40Gb MTP port on a network switch
Designed for high-density connections between 40GBASE-SR4 network equipment
Base-8 Fiber compatible with both QSFP+ 40GBASE-SR4 and QSFP28 100GBASE-SR4 connections
Multimode fiber optic fan-out cable supports various multi- and single-fiber connections.
Fully transmits 40GBASE-SR with four fibers transmitting at 10 Gbps in each direction
Magenta-colored for identification as an OM4 cable
MTP/MPO and LC Connectors with Push/Pull Tabs
● 1 male MTP/MPO and 8 male LC connectors
Push/pull tab connectors easy to install and remove with one hand
Error-Free Signal Transfer
1/3
8xLC Fan-Out Patch Cable,
Magenta, 3 m
Cleveland, OH 44122
United States
Premium-grade ceramic ferrule for 10 GbE and faster applications
Slim, space-saving uniboot design makes cable easier to manage
Plenum-rated jacket for connecting in ceilings, walls and ducts
Sturdy plastic housing built to last a long time
Specifications
OVERVIEW
UPC Code
037332200068
Technology
Multimode
Optical Mode
OM4
PHYSICAL
Cable Jacket Color
Magenta
Connector Color
Aqua; Magenta; Black
Cable Jacket Material
PVC
Cable Jacket Rating
OFNP
Clad Diameter (microns)
125
Core Diameter (microns)
50
Number of Fibers
12
Cable Length (ft.)
9.8
Cable Length (m)
2.99
Cable Length (in.)
118.1
Minimum Bend Radius
20MM (Dynamic); 10MM (Static)
Shipping Dimensions (hwd / in.)
9.00 x 7.00 x 0.50
Shipping Dimensions (hwd / cm)
22.86 x 17.78 x 1.27
Shipping Weight (lbs.)
0.17
Shipping Weight (kg)
0.08
ENVIRONMENTAL
Operating Temperature Range
-4 to 140 °F (-20 to 60 °C)
Storage Temperature Range
Operating Humidity Range
5% to 85% RH, Non-Condensing
Storage Humidity Range
35% to 65% RH, Non-Condensing
COMMUNICATIONS
Network Compatibility
40 Gbps; 100 Gbps; 400 Gbps
2/3
Cleveland, OH 44122
United States
Attenuation @ 850NM
3.0dB/Km
Insertion Loss
0.35dB
CONNECTIONS
Side A - Connector 1
12-STRAND MTP/MPO (FEMALE)
Side B - Connector 1
(8) LC DUPLEX (MALE)
Endface Polish
PC
FEATURES & SPECIFICATIONS
Push/Pull Tabs
Yes
Breakout
Yes
Trunk
Yes
STANDARDS & COMPLIANCE
Product Compliance
RoHS; REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N845-03M-8L-MG”相匹配的价格&库存,您可以联系我们找货
