N844-05M-12-P
N844-05M-12-P
    TRIPPLITE
    N844-05M-12-P
N844-05M-12-P 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States OM3 can support 40GBASE-SR4 / 100GBASE-SR10 in applicable parallel optics networks MTP/MPO Patch Cable, 12 Fiber, 40GbE, 40GBASE-SR4, OM3 Plenum-Rated - Aqua, 5M (16 ft.) MODEL NUMBER: N844-05M-12-P Highlights ● Hi-density MTP/MPO 12-fiber connectors for reduced cabling ● Push/Pull tab connectors offer maximum accessibility in high density installations; install / remove with one hand ● OM3 rated 50/125 Multimode ● Supports to 40GbE speeds Package Includes ● Features ● MTP / MPO Push-Pull Connectors for Quick Fiber Optic connections ● Push/Pull tab connectors offer maximum accessibility in high density installations; install / remove with one hand ● 12 times the density of SC style connectors ● High Density design cuts down on installation costs ● 50/125 OM3 Rated Multimode Fiber, 850nm ● Plenum rated jacket ● Unique cable ID label for Quality Control and Traceability ● Each cable 100% tested for low insertion loss and back reflection ● Test data supplied with each cable ● Custom lengths available Specifications OVERVIEW UPC Code 037332173744 Technology Multimode Optical Mode OM3 PHYSICAL Cable Jacket Color Aqua 1/3 5 Meter MTP / MPO Patch Cable, 12 Fiber, 40GbE Aqua OM3 Plenum 1000 Eaton Boulevard Cleveland, OH 44122 United States Connector Color Aqua; Black Cable Jacket Material PVC Cable Jacket Rating OFNP Clad Diameter (microns) 125 Core Diameter (microns) 50 Number of Fibers 12 Cable Length (ft.) 16.4 Cable Length (m) 5.00 Cable Length (in.) 196.9 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 7.00 x 9.00 x 0.50 Shipping Dimensions (hwd / cm) 17.78 x 22.86 x 1.27 Shipping Weight (lbs.) 0.12 Shipping Weight (kg) 0.05 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 40 Gbps; 100 Gbps; 400 Gbps Attenuation @ 850NM 3.0dB/Km Insertion Loss 0.35dB CONNECTIONS Side A - Connector 1 12-STRAND MTP/MPO (FEMALE) Side B - Connector 1 12-STRAND MTP/MPO (FEMALE) Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs Yes Breakout No Trunk No STANDARDS & COMPLIANCE 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N844-05M-12-P 价格&库存
很抱歉,暂时无法提供与“N844-05M-12-P”相匹配的价格&库存,您可以联系我们找货
