56LC-LM5
56LC-LM5
    GREENLEECOMMUNICATIONS(格林利)
    REFCAB MM50 LCPC
56LC-LM5 数据手册
REFCAB, MM50 LCPC Multimode Reference Cables:LC-PC to LC-PC Cat No: 56LC-LM5 UPC No: 783310606710 Description • • • • • Ensures accurate measurements for repeatable and reproducible testing to the latest industry standards Meets and/or exceeds the latest industry standards including: TIA/EIA-455-171 (FOTP-171A), issued June, 2001 TIA-568B, TIA-562-7 (OFSTP-7) and TIA-526-14 (OFSTP-14) for optical link testing TIA-455-171 (FOTP-171, Attenuation) and TIA-455-8 (FOTP-8,Return Loss) for cable assembly testing Corresponding IEC measurement standards Specifications • • • • • • • • • • • Beam Exit Angle : Greater Than Or Equal To 0.25DEG (SM) And Greater Than Or Equal To 0.5 DEG (MM) Connection : LC-PC To LC-PC Fiber Size : 50/125 UM Fiber to Ferrule Eccentricity : Greater Than Or Equal To 0.25UM (Singlemode) And Greater Than Or Equal To 3 UM (Multimode) Fiber Type : Multimode Insertion Loss : Greater Than Or Equal To 0.15DB (SM, 1310/1550 NMTR) And Greater Than Or Equal To 0.25 DB (MM, 850/1300 NMTR) Length : 3.000 M Outside Diameter : 2.4990 Plus Or Minus 0.0005 MM Ferrule Return Loss : Less Than Or Equal To 55 DB (SM, 1310/1550 NMTR) And Less Than Or Equal To 40 DB (MM, 850/1300 NMTR) Standard : TIA/EIA-455-171 (FOTP-171A), TIA-568B, TIA-562-7 (OFSTP-7),TIA-526-14 (OFSTP14), TIA-455-171 (FOTP-171, Attenuation),TIA-455-8 (FOTP-8, Return Loss), IEC Type : Standard, Type A To Type B
56LC-LM5
物料型号:56LC-LM5
器件简介:该文档描述的是GREENLEE品牌的REFCAB, MM50 LCPC多模参考光纤跳线,用于确保按照最新行业标准进行准确测量。
引脚分配:文档中没有提供引脚分配信息。
参数特性: - 光束出射角:单模大于等于0.25度,多模大于等于0.5度 - 连接类型:LC-PC至LC-PC - 光纤尺寸:50/125微米 - 光纤至套圈偏心:单模大于等于0.25微米,多模大于等于3微米 - 光纤类型:多模 - 插入损耗:单模大于等于0.15dB(1310/1550nm),多模大于等于0.25dB(850/1300nm) - 长度:3.000米 - 外径:2.4990±0.0005毫米 - 套圈回波损耗:单模小于等于55dB(1310/1550nm),多模小于等于40dB(850/1300nm)
功能详解:文档中没有提供详细的功能详解
应用信息:该光纤跳线用于光链路测试,符合TIA/EIA-455-171 (FOTP-171A), TIA-568B, TIA-562-7 (OFSTP-7), TIA-526-14 (OFSTP-14)等行业标准。
56LC-LM5 价格&库存
很抱歉,暂时无法提供与“56LC-LM5”相匹配的价格&库存,您可以联系我们找货
