N844-05M-8LC-PT
N844-05M-8LC-PT
    TRIPPLITE
    N844-05M-8LC-PT
N844-05M-8LC-PT 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States OM3 can support 40GBASE-SR4 / 100GBASE-SR10 in applicable parallel optics networks MTP/MPO Fan-out Cable with Push/Pull Tab Connectors, MTP/MPO to 4xLC, 40GbE, 40GBASE-SR4,OM3 Plenum-rated - Aqua, 5M (16.4 ft.) MODEL NUMBER: N844-05M-8LC-PT Highlights ● MTP / MPO to 8 x LC Fan-out Cable ● Push/Pull tab connectors offer maximum accessibility in high density installations; install / remove with one hand without needing additional tools ● Slim uniboot design saves space and makes cables easier to manage ● Premium-grade ceramic ferrule designed specifically for 10GbE and faster applications ● Sturdy plastic housing for longlasting durability ● OM3, 40GbE rated, 40GBASESR4 ● Backward compatible with existing 50/125 fiber ● Plenum rated jacket Package Includes ● Features ● MTP / MPO to 8 x LC Fan-out Cable ● Push/Pull tab connectors offer maximum accessibility in high density installations; install / remove with one hand without needing additional tools ● Slim uniboot design saves space and makes cables easier to manage ● Premium-grade ceramic ferrule designed specifically for 10GbE and faster applications ● Sturdy plastic housing for long-lasting durability ● OM3, 40GbE rated, 40GBASE-SR4 ● Backward compatible with existing 50/125 fiber ● Plenum rated jacket Specifications OVERVIEW UPC Code 037332185280 Technology Multimode Optical Mode OM3 PHYSICAL Cable Jacket Color Aqua 1/3 5M (16.4-ft.) MTP / MPO Fanout Cable, MTP/MPO to 8 x LC, 40GbE OM3 Plenum 1000 Eaton Boulevard Cleveland, OH 44122 United States Connector Color Aqua; Black; Aqua Cable Jacket Material PVC Cable Jacket Rating OFNP Clad Diameter (microns) 125 Core Diameter (microns) 50 Number of Fibers 8 Cable Length (ft.) 16.4 Cable Length (m) 5.00 Cable Length (in.) 196.9 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.20 Shipping Weight (kg) 0.09 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 40 Gbps; 100 Gbps; 400 Gbps Attenuation @ 850NM 3.0dB/Km Insertion Loss 0.35dB CONNECTIONS Side A - Connector 1 12-STRAND MTP/MPO (FEMALE) Side B - Connector 1 (8) LC DUPLEX (MALE) Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs Yes Breakout Yes Trunk Yes STANDARDS & COMPLIANCE 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N844-05M-8LC-PT 价格&库存
很抱歉,暂时无法提供与“N844-05M-8LC-PT”相匹配的价格&库存,您可以联系我们找货
