N846-01M-24-P
N846-01M-24-P
    TRIPPLITE
    PATCH CABLE FIBER
N846-01M-24-P 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States OM3 can support 40GBASE-SR4 / 100GBASE-SR10 in applicable parallel optics networks 100G MTP/MPO Multimode OM3 Plenum-Rated Fiber Optic Cable (CXP), 24 Fiber, 100GBASESR10, Push/Pull Tabs, Aqua, 1 m MODEL NUMBER: N846-01M-24-P Highlights ● Hi-density MTP/MPO 24-fiber connectors for reduced cabling ● Push/Pull tab connectors offer maximum accessibility in high density installations; install / remove with one hand ● OM3 rated 50/125 Multimode ● Supports to 100GbE speeds Package Includes ● Description Tripp Lite MTP/MPO to MTP/MPO fiber patch cables allow high-density connections between network equipment in telecommunication rooms. They feature Push/Pull tab connectors that offer maximum accessibility in high-density installations; install / remove with one hand. The MTP/MPO connector is approximately the same size of a SC connector but since it can accommodate 24 fibers, it provides up to 24 times the density, thereby offering savings in circuit card and rack space. N846 series cables are manufactured using laser-optimized, 50/125, OM3 multimode cable, and support speeds up to 100GbE. Features ● MTP / MPO Push-Pull Connectors for Quick Fiber Optic connections ● Push/Pull tab connectors offer maximum accessibility in high density installations; install / remove with one hand ● 24 times the density of SC style connectors ● No need for long fan-out cables or individual long duplex cable runs ● High-density design cuts down on installation costs ● 50/125 OM3 Rated Multimode Fiber, 850nm ● Plenum rated jacket ● Unique cable ID label for Quality Control and Traceability ● Each cable 100% tested for low insertion loss and back reflection ● Test data supplied with each cable ● Custom lengths available Specifications OVERVIEW 1/3 1 Meter MTP / MPO Patch Cable, 24 Fiber, 100GbE Aqua OM3 Plenum 1000 Eaton Boulevard Cleveland, OH 44122 United States UPC Code 037332173799 Technology Multimode Optical Mode OM3 PHYSICAL Cable Jacket Color Aqua Connector Color Aqua; Black; Blue Cable Jacket Material PVC Cable Jacket Rating OFNP Clad Diameter (microns) 125 Core Diameter (microns) 50 Number of Fibers 24 Cable Length (ft.) 3.3 Cable Length (m) 1.01 Cable Length (in.) 39.4 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.05 Shipping Weight (kg) 0.02 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 100 Gbps; 400 Gbps Attenuation @ 850NM 3.0dB/Km Insertion Loss 0.35dB CONNECTIONS Side A - Connector 1 24-STRAND MTP/MPO (FEMALE) Side B - Connector 1 24-STRAND MTP/MPO (FEMALE) Endface Polish PC 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States FEATURES & SPECIFICATIONS Push/Pull Tabs Yes Breakout No Trunk No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N846-01M-24-P 价格&库存
很抱歉,暂时无法提供与“N846-01M-24-P”相匹配的价格&库存,您可以联系我们找货
