N858-23M-3X8-MG
N858-23M-3X8-MG
    TRIPPLITE
    MTP/MPOMULTIMODEBASE-8TRUNKC
N858-23M-3X8-MG 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States MTP/MPO Multimode Base-8 Trunk Cable, 24Strand, 40GB/100GB, 40/100GBASE-SR4, OM4 Plenum-Rated (3xF/3xF), Push/Pull Tab, Magenta, 23 m (75 ft.) MODEL NUMBER: N858-23M-3X8-MG Highlights ● Push/pull tab connectors install/remove with one hand ● 8-fiber MTP/MPO connectors with 12x density of SC connectors ● 100% tested for low insertion loss and back reflection ● 50/125 OM4-rated multimode fiber ● Magenta color for easy OM4 identification Package Includes ● Premium multimode fiber optic cabling for transmitting 40/100 Gb data and voice signals. Designed for high-density connections between network equipment in telecom rooms and data centers. Features OM4-Rated for 40/100 Gb Ethernet Applications ● Designed to extend high-density connections between network equipment in telecom rooms and data centers ● Recommended for patching between data center MDFs and IDFs ● Optimized for QSFP+ 40GBASE-SR4 and QSFP28 100GBASE-SR4 networks ● Magenta-colored for identification as an OM4 cable MTP/MPO Connectors with Push/Pull Tabs ● 8-fiber female connectors 12 times denser than SC connectors ● Push/pull tab connectors easy to install and remove with one hand ● 100% tested for low insertion loss and back reflection Error-Free Signal Transfer ● 50/125 duplex glass fiber construction ● Plenum-rated jacket and bend-insensitive fiber perfect for ceilings, walls and ducts Specifications OVERVIEW UPC Code 037332200198 1/3 N858-23M-3X8-MG MTP/MPO Multimode Base-8 Trunk Cable, Magenta, 23 m 1000 Eaton Boulevard Cleveland, OH 44122 United States Technology Multimode Optical Mode OM4 PHYSICAL Cable Jacket Color Magenta Connector Color Magenta; Black Cable Jacket Material PVC Cable Jacket Rating OFNP Clad Diameter (microns) 125 Core Diameter (microns) 50 Number of Fibers 24 Cable Length (ft.) 75.5 Cable Length (m) 23.02 Cable Length (in.) 905.5 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 3.74 x 8.27 x 8.27 Shipping Dimensions (hwd / cm) 9.50 x 21.01 x 21.01 Shipping Weight (lbs.) 2.36 Shipping Weight (kg) 1.07 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 40 Gbps; 100 Gbps; 400 Gbps Attenuation @ 850NM 3.0dB/Km Insertion Loss 0.35dB CONNECTIONS Side A - Connector 1 (3) 8-STRAND MTP/MPO (FEMALE) Side B - Connector 1 (3) 8-STRAND MTP/MPO (FEMALE) Endface Polish PC FEATURES & SPECIFICATIONS 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Push/Pull Tabs Yes Breakout Yes Trunk Yes STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N858-23M-3X8-MG 价格&库存
很抱歉,暂时无法提供与“N858-23M-3X8-MG”相匹配的价格&库存,您可以联系我们找货
