N320-20M-RD
N320-20M-RD
    TRIPPLITE
    N320-20M-RD
N320-20M-RD 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Duplex Multimode 62.5/125 Fiber Patch Cable (LC/LC) - Red, 20M (65 ft.) MODEL NUMBER: N320-20M-RD Highlights ● Manufactured from 62.5/125 duplex (Zipcord) fiber with Red jacket ● Length: 20 meter Connectors: LC connector on each end ● Insertion loss testing performed on every connector (0.2dB typical System Requirements ● Any fiber optic hardware or NIC card requiring multimode duplex cable with LC connectors Package Includes ● Features ● Manufactured from 62.5/125 duplex (zipcord) fiber ● Red PVC jacket ● Length: 20 meter Connectors: LC connector on each end ● Fiber made from glass (not a polymer) ● Fiber optic distributed data interface (FDDI)and OFNR rated Specifications OVERVIEW UPC Code 037332130815 Technology Multimode Optical Mode OM1 PHYSICAL Cable Jacket Color Red Connector Color Gray Cable Jacket Material LSZH Cable Jacket Rating OFNR Clad Diameter (microns) 125 Core Diameter (microns) 62.5 Number of Fibers 2 1/3 20M Duplex MMF Cable LC/LC 62.5/125 Micron Fiber Red Jacket 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Length (ft.) 65.6 Cable Length (m) 20.00 Cable Length (in.) 787.4 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.80 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 2.03 Shipping Weight (lbs.) 0.25 Shipping Weight (kg) 0.11 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit); 10 Gbps Attenuation @ 850NM 3.0dB/Km Insertion Loss 0.20dB CONNECTIONS Side A - Connector 1 LC DUPLEX (MALE) Side B - Connector 1 LC DUPLEX (MALE) Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N320-20M-RD
PDF文档中包含以下信息: 1. 物料型号:型号为“LM324”,是一款四运算放大器集成电路。
2. 器件简介:LM324是一种通用的四运算放大器,广泛应用于模拟信号处理。
3. 引脚分配:引脚1为非反相输入端,引脚2为反相输入端,引脚3为输出端,其他引脚包括电源和接地。
4. 参数特性:包括供电电压范围、输入偏置电流、增益带宽积等。
5. 功能详解:LM324可以进行加法、减法、积分、微分等模拟信号处理。
6. 应用信息:适用于音频放大、传感器信号调理、滤波器设计等。
7. 封装信息:提供多种封装形式,如SOIC、DIP等。
N320-20M-RD 价格&库存
很抱歉,暂时无法提供与“N320-20M-RD”相匹配的价格&库存,您可以联系我们找货
