N424-05M
N424-05M
    TRIPPLITE
    FIBERCONDPATCHCABLESC-LC5M
N424-05M 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Fiber Optic Mode Conditioning Patch Cable (SC/LC), 5M (16 ft.) MODEL NUMBER: N424-05M Highlights ● Converts Singelemode SC GBIC to Multimode LC Patch Panel ● 62.5/125 and 9/125 ● Run 1000Base-LX Gigabit Ethernet over MMF by offsetting signal loss Package Includes ● Features ● Use SC GBIC Singlemode Transceivers on Multimode Fiber Backbones with LC patch bays ● 62.5/125 and 9/125 ● Offsets the Singlemode Laser launch from the center of a Multimode fiber ● Available in a variety of connector combinations Specifications OVERVIEW UPC Code 037332127266 Optical Mode OM1 PHYSICAL Cable Jacket Color Orange; Yellow Connector Color Blue; Gray; Black Cable Jacket Material PVC Cable Jacket Rating OFNR Clad Diameter (microns) 125 Core Diameter (microns) 62.5 Number of Fibers 2 Cable Length (ft.) 16.4 1/3 SC / Mode Conditioning to LC Fiber Optic Patch Cable, 5M ( 16-ft. ) 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Length (m) 5.00 Cable Length (in.) 196.9 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.16 Shipping Weight (kg) 0.08 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Attenuation @ 850NM 3.0dB/Km Insertion Loss MM TO MM0.20dB;MM TO SM0.30dB CONNECTIONS Side A - Connector 1 LC DUPLEX (MALE) Side B - Connector 1 SC DUPLEX (MALE) Endface Polish PC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N424-05M 价格&库存
很抱歉,暂时无法提供与“N424-05M”相匹配的价格&库存,您可以联系我们找货
