电子发烧友
开通电子发烧友VIP会员 尊享10大特权
海量资料免费下载
精品直播免费看
优质内容免费畅学
课程9折专享价
CSI-RSFB-300-UFFR
CSI-RSFB-300-UFFR
    LINXTECHNOLOGIES(灵思)
    CABLERPSMA-UMCC300MM
CSI-RSFB-300-UFFR 数据手册
RF Connector Overview Guide Linx Technologies offers a wide variety of SMA, MCX, MMCX and MHF radio frequency connector and cable assemblies. RF connectors and cables consist of miniature precision-machined mechanical components and clever designs with complex assembly which are necessary to minimize losses and reflections. This requries tight tolerances, quality surface finishing and proper choice of metals and insulators. By combining domestic design and quality with offshore connector manufacturing, Linx offers low loss connectors at very competitive prices for OEM customers. –1– Revised 2/19/15 SMA Connectors SMA (subminiature version A) connectors are high performance coaxial RF connectors with 50-ohm matching and excellent electrical performance up to 18GHz with insertion loss as low as 0.17dB. They also have high mechanical strength through their thread coupling. This coupling minimizes reflections and attenuation by ensuring uniform contact. SMA connectors are among the most popular connector type for OEMs as they offer high durability, low VSWR and a variety of antenna mating choices. In order to comply with FCC Part 15 requirements for non-standard antenna connectors, SMA connectors are also available in reverse polarity (RP-SMA). Cable Termination SMA and RP-SMA Connecctors Connector Type Orientation Mount Style Cable Types Body Finish SMA007 Straight Crimp End Plug RG-174, RG-188A, RG-316 Nickel Polarity Part Numbers Standard CONSMA007 Reverse CONREVSMA007 Standard CONSMA007-R58 Reverse CONREVSMA007-R58 Standard CONSMA007-R178 Reverse CONREVSMA007-R178 Standard CONSMA012 Reverse CONREVSMA012 Standard CONSMA012-R58 Reverse CONREVSMA012-R58 Standard CONSMA012-R178 Reverse CONREVSMA012-R178 Standard CONSMA011 Reverse CONREVSMA011 Standard CONSMA011-R58 Reverse CONREVSMA011-R58 Standard CONSMA011-R178 CONREVSMA003.031 Reverse CONREVSMA011-R178 Standard CONSMA003.062 Standard CONSMA005 Reverse CONREVSMA003.062 Reverse CONREVSMA005 Standard CONSMA005-R58 Reverse CONREVSMA005-R58 Standard CONSMA05-R178 Reverse CONREVSMA05-R178 Standard CONSMA014 Reverse CONREVSMA014 Standard CONSMA014-R58 Reverse CONREVSMA014-R58 Standard CONSMA014-R178 Reverse CONREVSMA014-R178 Standard CONSMA015 Reverse CONREVSMA015 Standard CONSMA015-R178 Reverse CONREVSMA015-R178 SMA007-R58 SMA007-R178 Straight Straight Crimp End Crimp End RG-58/58A/58C, RG-141A Plug Plug RG-178, RG-196 Nickel Nickel PCB Board Termination SMA and RP-SMA Connectors Connector Type Orientation Mount Style Board Thickness Body Finish Nickel SMA001 Straight Through-hole Gold Receptacle Nickel Gold Nickel SMA001-SMD Straight Surface-mount Gold Receptacle Nickel Gold Straight Edge Receptacle Nickel 0.062 in Edge, Bulkhead Straight Receptacle Nickel 0.031 in Edge Plug Nickel 0.062 in Right Angle Through-hole Gold Receptacle Nickel Gold Nickel SMA002-SMD Right Angle Surface-mount Gold Receptacle Nickel Gold SMA009 SMA002-L SMA008 Right Angle Right Angle, Extended Straight, Extended Edge Through-hole, Bulkhead Through-hole Receptacle 0.062 in Receptacle Nickel Straight, Extended Edge CONSMA001-G CONREVSMA001 CONREVSMA001-G CONSMA001-SMD CONSMA001-SMD-G CONREVSMA001-SMD Nickel Receptacle Nickel 0.062 in Right Angle Crimp End Plug RG-174, RG-188A, RG-316 Nickel SMA012-R58 Right Angle Crimp End Plug RG-58/58A/58C, RG-141A Nickel SMA012-R178 Right Angle Crimp End Plug RG-178, RG-196 Nickel SMA011 Straight Crimp End Receptacle RG-174, RG-188A, RG-316 Nickel SMA011-R58 Straight Crimp End Receptacle CONREVSMA001-SMD-G CONSMA003.031 SMA011-R178 SMA005 CONSMA006.031 Reverse CONREVSMA006.031 Standard CONSMA006.062 CONREVSMA006.062SQ Standard CONSMA013.031 Reverse CONREVSMA013.031 Standard CONSMA013.062 Standard Reverse Standard Reverse CONREVSMA013.062 Straight Straight Crimp End Crimp End, Bulkhead Receptacle Receptacle RG-58/58A/58C, RG-141A RG-178, RG-196 RG-174, RG-188A, RG-316 Nickel Nickel Nickel SMA005-R58 Straight Crimp End, Bulkhead Receptacle RG-58/58A/58C, RG-141A Nickel SMA005-R178 Straight Crimp End, Bulkhead Receptacle RG-178, RG-196 Nickel SMA014 Straight Crimp End, Bulkhead, Rear-Mount Receptacle RG-174, RG-188A, RG-316 Nickel SMA014-R58 Straight Crimp End, Bulkhead, Rear-Mount Receptacle RG-58/58A/58C, RG-141A Nickel SMA014-R178 Straight Crimp End, Bulkhead, Rear-Mount Receptacle RG-178, RG-196 Nickel SMA015 Straight Crimp End, Bulkhead, Front-Mount Receptacle RG-174, RG-188A, RG-316 Nickel CONSMA002 CONSMA002-G CONREVSMA002 SMA015-R178 CONREVSMA002-G Straight Crimp End, Bulkhead, Front-Mount Receptacle RG-178, RG-196 Nickel CONSMA002-SMD CONSMA002-SMD-G CONREVSMA002-SMD CONREVSMA002-SMD-G SMA Connector General Specifications Standard CONSMA009.062 Materials Reverse CONREVSMA009.062 Connector Part Standard CONSMA002-L Reverse Receptacle SMA012 CONSMA001 Nickel 0.031 in SMA003-L Reverse Reverse Nickel SMA002 Reverse Reverse Edge, Square Flange Straight Standard Part Numbers CONREVSMA006.062 0.062 in SMA013 Reverse Standard 0.031 in SMA006 Standard Standard 0.031 in SMA003 Polarity Bodies CONREVSMA002-L Standard CONSMA008 Reverse CONREVSMA008 Standard CONSMA003.031-L Reverse CONREVSMA003.031-L Standard CONSMA003.062-L Reverse CONREVSMA003.062-L Center Contact Electrical Material Finish Electrical Data Detail Brass Nickel or Gold Impedance 50-ohm Stainless Steel (Special Order) Passivated or Gold Male: Brass Female: Beryllium Copper Frequency Range Gold Insulator PTFE N/A Crimp Ferrule Annealed Copper Nickel or Gold Insertion Loss VSWR: f(GHz) Flexible cable: 0–12.4GHz Semi-rigid cable: 0–18GHz 0.04dB max. √f GHz (straight) 0.06dB max. √f GHz (right angle) RG-178/U ST: 1.20+0.025f RA: 1.20+0.03f RG-174, 316/U ST: 1.15+0.02f RA: 1.15+0.03f RG-58, 141, 142, 223/U ST: 1.10+0.01f RA: 1.15+0.02f MCX Connectors MMCX Connectors MCX (micro coaxial) connectors are subminiature RF connectors that offer strong electrical performance in a smaller size, compared to SMAs and SMBs. The outer diameter of the plug is approximately 2.6 mm or 0.140 inch. Linx MCX connectors are available at 50-ohms and operate up to 6GHz at less than 0.2dB insertion loss. Their small size and snap-on connection is ideal for dense packaging such as those in consumer products, GPS and automotive application. MMCX (micro-miniature coaxial) connectors are similar to the MCX but smaller and approximately one third lighter. MMCX connectors are matched to 50-ohms and operate up to 6GHz with less than 0.3dB insertion loss. The connectors have a snap locking mechanism which allows 360° rotation. Because of their small size, MMCX connectors are popular in consumer products, PCS devices and GPS applications. PCB Board Termination MMCX Connectors PCB Board Termination MCX and RP-MCX Connectors Connector Type Orientation Mount Style Board Thickness MCX001 Straight Through-hole Receptacle MCX001-SMD Straight Surface-mount Receptacle MCX003 Straight Edge Receptacle MCX002 Right Angle Through-hole MCX002-SMD Right Angle Surface-mount MCX003-L Straight, Extended Body Finish Polarity Part Numbers Gold Standard CONMCX001 Standard CONMCX001-SMD Reverse CONREVMCX001-SMD Gold 0.031 in Standard Receptacle Gold Standard CONMCX002 Receptacle Gold Standard CONMCX002-SMD Reverse CONREVMCX002-SMD 0.062 in 0.031 in Edge CONMCX003.031 Gold Receptacle 0.062 in MCX007 Orientation Straight Mount Crimp End Orientation Mount Style Body Finish Polarity Part Numbers MMCX001 Straight Through-hole Receptacle Gold Standard CONMMCX001 MMCX001-SMD Straight Surface-mount Receptacle Gold Standard CONMMCX001-SMD MMCX002 Right Angle Through-hole Receptacle Gold Standard CONMMCX002 MMCX002-SMD Right Angle Surface-mount Receptacle Gold Standard CONMMCX002-SMD CONMCX003.062 Cable Termination MMCX Connectors Connector Type Orientation Mount Style Cable Types Body Finish Polarity Part Numbers MMCX007 Straight Crimp End Plug RG-174, RG-188A, RG-316 Gold Standard CONMMCX007 MMCX007-R178 Straight Crimp End Plug RG-178, RG-196 Gold Standard CONMMCX007-R178 MMCX012 Right Angle Crimp End Plug RG-174, RG-188A, RG-316 Gold Standard CONMMCX012 MMCX012-R178 Right Angle Crimp End Plug RG-178, RG-196 Gold Standard CONMMCX012-R178 MMCX011 Straight Crimp End Receptacle RG-174, RG-188A, RG-316 Nickel Standard CONMMCX011 MMCX011-R178 Straight Crimp End Receptacle RG-178, RG-196 Nickel Standard CONMMCX011-R178 CONMCX003.031-L Gold Standard CONMCX003.062-L Cable Termination MCX and RP-MCX Connectors Connector Type Connector Type Style Cable Types Body Finish Plug RG-174, RG-188A, RG-316 Gold Polarity Part Numbers Standard CONMCX007 Reverse CONREVMCX007 MCX007-R178 Straight Crimp End Plug RG-178, RG-196 Gold Standard CONMCX007-R178 MCX012 Right Angle Crimp End Plug RG-174, RG-188A, RG-316 Gold Standard CONMCX012 MCX012-R178 Right Angle Crimp End Plug RG-178, RG-196 Gold Standard CONMCX012-R178 Materials Standard CONMCX011 Connector Part Material Finish Receptacle RG-174, RG-188A, RG-316 Reverse CONREVMCX011 Bodies Brass Nickel or Gold Standard CONMCX011-R178 MCX011 MCX011-R178 MCX005 MCX005-R178 Straight Straight Crimp End, Bulkhead Crimp End, Bulkhead Straight Crimp End, Bulkhead Straight Crimp End, Bulkhead Receptacle Receptacle Receptacle –4– RG-178, RG-196 RG-174, RG-188A, RG-316 RG-178, RG-196 Gold Gold Gold Gold Standard CONMCX005 Reverse CONREVMCX005 Standard CONMCX005-R178 MCX and MMCX Connector General Specifications Center Contact Electrical Male: Brass Female: Beryllium Copper Gold Insulator PTFE N/A Crimp Ferrule Annealed Copper Nickel or Gold Electrical Data Detail Impedance 50-ohm Frequency Range 0–6GHz Insertion Loss (MCX) Insertion Loss (MMCX) 0.1dB max. (straight) 0.2dB max. (right angle) 0.2dB max. at 1GHz (straight) 0.3dB max. at 1GHz (right angle) MCX VSWR f(GHz) –5– RG-178/U ST: 1.17+0.04f RA: 1.07+0.06f RG-316/U ST: 1.13+0.04f RA: 1.07+0.04f MMCX ST: 1.3 max. RA: 1.5 max. Cable Assembly Capabilities Connector Choices for Cable Assemblies Connector Choices for Cable Assemblies Cable Length Tolerance Type Connector A Style Orientation Connector B Finish Nickel Straight Gold Plug Nickel Right Angle Gold Cable length tolerance 1.5% or or 12.7 12.7 mm mm(½"), (½"),whichever whichever is greater. Cable length toleranceisis±±1.5% is greater. Nickel Receptacle Straight Gold Cable Assembly Part Numbering System SMA Nickel Our part numbers are structured as follows: Receptacle, Rear-Mount, Bulkhead Straight Gold CNA - RSFB - 12345 - RSFM Connector B Length (in mm) Connector A Cable Status Product Family Identifier Nickel Receptacle, Rear-Mount, Sealed, Bulkhead Straight Gold Nickel Receptacle, Front-Mount, Sealed, Bulkhead Straight Gold Cable Codes and Specifications Cable Type Code Description A RG-174 B Impedance 200MHz 400MHz 700MHz 900MHz 50Ω 27.6 41 62.3 88.6 101/8 RG-178 50Ω 52.49 C RG-58 50Ω 14.8 D RG-58LL 50Ω E RG-316 50Ω I 1.13mm 50Ω 108.27 1.8GHz 2.45GHz 5.2GHz 5.8GHz 32.8 45.9 52.8 4.66 6.32 8.45 9.67 68.9 Right Angle Gold MCX Receptacle 170.61 22.3 36.09 1GHz Gold Plug Attenuation (dB/100M) 100MHz Straight Receptacle, Rear-Mount, Bulkhead 3.9 Cable Status Codes Connector Specifications Status Code Description Series Impedance Frequency Range Insertion Loss C Custom SMA & RP-SMA 50Ω 0–12.4GHz 0.04dB max S Stock* MCX & RP-MCX 50Ω 0–6GHz N Non-stock MMCX 50Ω 0–6GHz Standard SMAM Reverse RPSM Standard SGAM Reverse RGSM Standard SAMR Reverse RSMR Standard SGMR Reverse RGMR Standard SMAF Reverse RPSF Standard SGAF Reverse RGSF Standard SAFB Reverse RSFB Standard SGFB Reverse RGFB Standard SAFI Reverse RSFI Standard SGFI Reverse RGFI Standard SAFE Reverse RSFE Standard SGFE Reverse RGFE Standard MCXM Reverse RPXM Standard MXMR Reverse RXMR Standard MCXF Reverse RPXF Standard MXFB Reverse RXFB Gold Straight Gold Standard MMXM Right Angle Gold Standard MMMR Receptacle Straight Gold Standard MMXF Receptacle, Rear-Mount, Bulkhead Straight Gold Standard MMFB MHF / U.FL Plug Right Angle Gold Standard UFFR Straight Cut N/A N/A N/A N/A STCT Strip & Tin N/A N/A N/A N/A STTN 124.68 2.6 Gold Connector Code Straight 10.2 2.2 Straight Polarity 4.3 Plug MMCX Note: Illustrations are not representative of the final product –6– –7– Cable Customization Capabilities Properly stripping a coaxial cable and attaching it to the connector requires special fixtures and experience. Unlike digital cables, a small deviation from the ideal attachment may yield key parameters that are out of specification. Prudent customers often buy pre-built cables from Linx to benefit from Linx’s quality systems, fixtures and RF expertise. In-house cable finishing allows Linx to quickly deliver a variety of cable lengths and connector combinations. Linx Technologies Headquarters Linx corporate headquarters are located in a beautiful custom-built facility in Merlin, Oregon, which is in the Rogue Valley near Grants Pass and the Rogue River. Linx Technologies is continually striving to improve the quality and function of its products. For this reason, we reserve the right to make changes to our products without notice. The information contained in this Data Guide is believed to be accurate as of the time of publication. Specifications are based on representative lot samples. Values may vary from lot-to-lot and are not guaranteed. “Typical” parameters can and do vary over lots and application. Linx Technologies makes no guarantee, warranty, or representation regarding the suitability of any product for use in any specific application. It is Customer’s responsibility to verify the suitability of the part for the intended application. At Customer’s request, Linx Technologies may provide advice and assistance in designing systems and remote control devices that employ Linx Technologies RF products, but responsibility for the ultimate design and use of any such systems and devices remains entirely with Customer and/or user of the RF products. Some customers may want Linx radio frequency (“RF”) products to control machinery or devices remotely, including machinery or devices that can cause death, bodily injuries, and/or property damage if improperly or inadvertently triggered, particularly in industrial settings or other applications implicating life-safety concerns (“Life and Property Safety Situations”). NO OEM LINX REMOTE CONTROL OR FUNCTION MODULE SHOULD EVER BE USED IN LIFE AND PROPERTY SAFETY SITUATIONS. No OEM Linx Remote Control or Function Module should be modified for Life and Property Safety Situations. Such modification cannot provide sufficient safety and will void the product’s regulatory certification and warranty. Customers may use our (non-Function) Modules, Antenna and Connectors as part of other systems in Life Safety Situations, but only with necessary and industry appropriate redundancies and in compliance with applicable safety standards, including without limitation, ANSI and NFPA standards. It is solely the responsibility of any Linx customer who uses one or more of these products to incorporate appropriate redundancies and safety standards for the Life and Property Safety Situation application. Copyright © 2014 Linx Technologies Phone: +1 541 471 6256 Fax: +1 541 471 6251 www.linxtechnologies.com Oregon HQ 159 Ort Lane Merlin, OR 97532 –8–
CSI-RSFB-300-UFFR 价格&库存
很抱歉,暂时无法提供与“CSI-RSFB-300-UFFR”相匹配的价格&库存,您可以联系我们找货
    • 15+ 75.91001 15+ 0
    • 35+ 74.53028 35+ 0
    • 65+ 73.15055 65+ 0
    • 100+ 70.30408 100+ 0
    • 250+ 66.6248 250+ 0
    • 500+ 64.23824 500+ 0
    库存:1153
