C58LL-RPSM-2438-NM
C58LL-RPSM-2438-NM
    LINXTECHNOLOGIES(灵思)
    C58LL-RPSM-2438-NM
C58LL-RPSM-2438-NM 数据手册
Description Body Pin Insulation Heat Shrink Material Brass BE CU PTFE Polyolefin Finish Nickel Gold N/A Black REVISIONS REV B C DESCRIPTION DATE Revised RP-SMA connector Added new title block APPV 10/29/09 CJ 12-JUL-12 BPM RG-58LL Cable 0.79 [20.0] 0.79 [20.0] 96.0 [2438] NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. 2. DIMENSIONS APPLY AFTER FINISHING. : THIS DRAWING CONTAINS PROPRIETARY INFORMATION 159 ORT LANE THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. MATERIAL: FINISH: PROJECTION: TOLERANCES: .020 [0.50]-.200 [5.00]= .008 [0.20] .200 [5.00]-1.200 [30.00]= .016 [0.40] 1.20 [30.0]-4.75 [120.0]= .024 [0.60] 4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1 DRAWN: CJ ENGR: DT: 10/29/09 DT: TITLE: MERLIN, OR 97532 RPSMA MALE TO N MALE WITH 8’ OF RG58 LOW LOSS CABLE SIZE DWG. NO. REV C58LL-RPSM-2438-NM SCALE: 2:1 DO NOT SCALE DRAWING C SHEET 1 OF 1 LDCFDLT_A
C58LL-RPSM-2438-NM 价格&库存
很抱歉,暂时无法提供与“C58LL-RPSM-2438-NM”相匹配的价格&库存,您可以联系我们找货
C58LL-RPSM-2438-NM
  • 1+198.33153
  • 10+194.36386
库存:9
