F6-75B
F6-75B
    TPI(TPI 公司)
    F6-75B
F6-75B 数据手册
The Value Leader ™ BNC to BNC Coax Cable Assemblies: Used in Serial Digital, Communication, HDTV, and Broadband Applications • UL Listed Cable: Ensures quality and consistency in the cable construction. • Boot is molded to cable connector for added strength: Limits the amount of bending the cable is exposed to at the connector to prevent cable breakage. • Gold center pins: Ensures that there is a high quality connection maintaining the best return loss in high definition applications. • Machined Brass Connectors: Unlike die-cast connectors, machined brass connectors have more precise tolerances, strength and positive mating meaning low signal loss for precise video and data applications. • 95% Shielding: Keeps unwanted RF interference from infiltrating your signal giving you nice, clean output. • 80º temperature rating: Applicable to any application found indoors. • Lengths Available up to 100 ft.: Easily route cables into other rooms or floors. • Individually bagged F Cables with Screw-on Ends: Used in Broadband Applications • UL Listed Cable: Ensures quality and consistency in the cable construction. • RG-6: Cable type that is standard in the video and cable TV industry • Molded Ends: Limits the amount of bending the cable is exposed to at the connector to prevent cable breakage. • Screw-on F-Type Connectors: Ensure positive connection thus eliminating shadows in the picture. • Lengths Available up to 100 ft.: Easily route cables into other rooms or floors. • Available in black or white: Easily hide the cable along walls or behind equipment. • Individually bagged Molded BNC to BNC Cable Assemblies RG58/U, BNC Male to Male Instrumentation & Data RG59/U, BNC Male to MaleVideo & General 50 Ohm 75 Ohm Part No. 58-012-1M 58-024-1M 58-036-1M 58-048-1M 58-060-1M 58-072-1M 58-120-1M 58-180-1M 58-300-1M 58-600-1M 58-900-1M 58-1200-1M Length 12 inch 24 inch 36 inch 48 inch 60 inch 72 inch 10 feet 15 feet 25 feet 50 feet 75 feet 100 feet RG62/U, BNC Male to MaleComputer & Lab 93 Ohm Part No. 62-024-1M 62-036-1M 62-048-1M 62-060-1M Length 24 inch 36 inch 48 inch 60 inch F Series Cables Part No. 59-012-1M 59-024-1M 59-036-1M 59-048-1M 59-060-1M 59-072-1M 59-120-1M 59-180-1M 59-300-1M 59-600-1M 59-900-1M 59-1200-1M Length 12 inch 24 inch 36 inch 48 inch 60 inch 72 inch 10 feet 15 feet 25 feet 50 feet 75 feet 100 feet Assembled BNC to BNC Cable Assemblies RG58/U, BNC Male to Male Instrumentation & Data White F6-3W F6-6W F6-10W F6-12W F6-15W F6-25W F6-50W F6-75W F6-100W L BNC-0805 Conductor Insulation Braided Shielding Jacket General RG58 Material BC No./mm 1/0.813 Material LDPE Color Natural Diameter (mm) 2.95 Material BC No./mm 16/7/0.12 Material PVC Thickness (mm) 0.72 Color Black Outer Diameter (mm) 4.95 ±0.15 Tensile Strength 1,500 psi Nominal Impedance (Ohm) 53.5 Nominal Capacitance (pF/m) 93.5 Attenuation 100MHz (db/km) 138 Voltage Rating 5.0kv UL Standard 1354 Part No. 58-024-1A 58-036-1A 58-048-1A 58-060-1A Length 24 inch 36 inch 48 inch 60 inch RG59 CCS 1/0.643 LDPE Natural 3.71 BC 16/7/0.12 PVC 0.9 Black 6.0 ±0.15 1,500 psi 73 68.9 125 7.0kv 1354 F Series Cable Technical Specifications RG-6 Conductor Insulation Material CCS No./mm 1/1.02 Material FPE Color Braided Shielding Jacket White Diameter (mm) 4.7 Material OFC No./mm 16/4/0.12 Material PVC Thickness (mm) Length 3’ 6’ 10’ 12’ 15’ 25’ 50’ 75’ 100’ 3’ 6’ 10’ 12’ 15’ 25’ 50’ 75’ 100’ Copyright © 2005 Test Products International, Inc. RG62 CCS 1/0.643 LDPE Natural 3.71 BC 16/7/0.12 PVC 1 Black 6.15 ±0.15 1,500 psi 93 44.3 102 3.0kv 1354 BC = Bare Copper CCS = Copper Clad Steel LDPE = Low Density PE 50 Ohm RG-6 Video & General Part No. Black F6-3B F6-6B F6-10B F6-12B F6-15B F6-25B F6-50B F6-75B F6-100B BNC to BNC Coax Cable Technical Specifications Color General 1 Black or White Outer Diameter (mm) 7.2 ±0.2 Tensile Strength 1,500 psi Nominal Impedance (Ohm) 73 Nominal Capacitance (pF/m) 59 Attenuation 100MHz (db/km) 89 Voltage Rating 3.0kv UL Standard 1354 CCS = Copper Clad Steel FPE = Foam Polyethylene OFC = Oxygen Free Copper Test Products International, Inc. 9615 SW Allen Blvd., Ste. 104 • Beaverton, OR 97005 503-520-9197 • Fax: 503-520-1225 www.testproductsintl.com
F6-75B 价格&库存
很抱歉,暂时无法提供与“F6-75B”相匹配的价格&库存,您可以联系我们找货
