SMA Male to FME Male Low Loss - 10M
ASMA1000E058L13
Features
Up to 6GHz
SMA Male
FME Male
Low Loss
The Siretta low loss extension cable range offers a number of different connector types and cable length
options to help meet your specific requirements for RF installation. The effectiveness of your wireless
application is often influenced by being able to mount your antenna in the most optimum position for
signal strength. A Siretta low loss extension cable can help achieve this and gain the best performance
from your wireless application. Siretta\'s range of low loss RF extension cable assemblies are made with
high quality LLC200A coaxial cable - detailed specifications of this cable can be found by clicking on the
‘Electrical’ and ‘Mechanical’ tabs above. The inherent very low loss of the LLC200A allows longer cable
runs to be employed while maintaining acceptable signal strength. The LLC200A cable is robust and
flexible, and with a diameter of 4.95mm similar to standard RG58. However, it is not suitable for
applications where a tight bend radius of less that 20mm is required.
This product page contains SMA male to FME male extension cable assemblies using LLC200A coax
cables. The FME is one of the most commonly used connector types for wireless systems due to its
compact size and reliable screw engagement with the mating connector. The SMA male to FME female
cable assembly is offered in both 3 (http://www.siretta.co.uk/new/product.php?id=1030), 5
(http://www.siretta.co.uk/new/product.php?id=1031), 10
(http://www.siretta.co.uk/new/product.php?id=1027), 15
(http://www.siretta.co.uk/new/product.php?id=1028) and 20
(http://www.siretta.co.uk/new/product.php?id=1029) metre cable lengths.
You are currently viewing the 10 metre version of the SMA Male to FME Male Low Loss RF cable.
Parts
ASMA1000E058L13
SMA Male to FME
Male Low Loss 10M
Images
Specifications
Cable Specifications
Impedance: 50 ohm
Loss dB/M @ 1.8GHz: 0.52, @ 2.1GHz: 0.64
Operating Frequencies
Up to 6GHz
Dimensions
Core: 0.94mm copper wire
Insulator: 2.79mm GAS-FPE
Shield: tinned copper braid
Jacket: 4.95mm PVC
Mounting Specifications
Connector: SMA Male to FME male
Cable: LLC200A
https://www.siretta.co.uk/product.php?id=1027&rid=&rpage=search
7/7/2016
很抱歉,暂时无法提供与“ASMA1000E058L13”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+472.18420
- 5+462.74927
