7012-0799
7012-0799
    AMPHENOLSVMICROWAVE(安费诺MAO)
    SMPFEMALER/ATOSMPFEMALER/A
7012-0799 数据手册
ROHS COMPLIANT PRODUCT DATA DRAWING REVISION HISTORY DESCRIPTION REV DATE APPROVED 01 PRELIMINARY 03/14 STW - NRN 38806 05/14 STW L±.125 OAL (SEE TABLE) SV P/N L (OAL) INSERTION LOSS dB MAX. 7012-0799 6.000" 1.29 7012-0800 12.000" 1.96 7012-0801 24.000" 3.30 MATERIAL: 2 SMP R/A FEMALE CONNECTORS: 1214-4001 T-FLEX 405 CABLE: 200-70-139 SINGLE WALL TUBING: M23053/5 (BLACK) PERFORMANCE: IMPEDANCE: FREQ. RANGE: VSWR: INSERTION LOSS: 50 OHMS DC TO 26.5 GHz 1.85:1 DC TO 26.5 GHz SEE TABLE MATERIAL: FINISH: SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: BNK 03/27/14 CHECKED: APPROVED: STW 03/27/14 STW 03/27/14 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMP R/A FEMALE TO SMP R/A FEMALE T-FLEX 405 CABLE ASSEMBLY SIZE CAGE CODE DWG. NO. B 95077 SCALE: 6:1 7012-0799-0801 SHEET 1 OF 1
7012-0799 价格&库存
很抱歉,暂时无法提供与“7012-0799”相匹配的价格&库存,您可以联系我们找货
