851
851
    ADAFRUIT
851 数据手册
SMA to uFL/u.FL/IPX/IPEX RF Adapter Cable PRODUCT ID: 851  Description This RF adapter cable is super handy for anyone doing RF work. Often times, small electronics save space by having a pick-and-placeable u.FL connector (also called uFL, IPEX, IPAX, IPX, MHF, and AM). But most antennas have SMA or RP-SMA connectors on them. This little cable will bridge the two! This cable is RG178 and is 15cm (5.9") long not including the SMA connector. It has a panel-mount SMA connector on the end, often used for GPS and cellular connections. Most WiFi devices/routers that have a connector use RP-SMA. Check the antenna you want to connect, and the close up image above to verify if you need RP-SMA or SMA as they are not compatible! Technical Details        Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“851”相匹配的价格&库存,您可以联系我们找货
