FC75-01-CA003
FC75-01-CA003
    CICOIL
    COAXCABLE75OHM3'1C
FC75-01-CA003 数据手册
4 3 2 FC75-01-CA003 FC75-01-CA006 FC75-01-CA012 D NUMBER OF CONDUCTORS LENGTH IN FEET FC75-02-CA003 FC75-02-CA006 FC75-02-CA012 ZONE ALL NOTES: 1 INSTALL CONNECTORS AND HEAT SHRINK AS NEEDED FLEXIBLE COAX 75 OHM, FC75-01-CAXXX QTY DESCRIPTION PART NUMBER FN 2 THE ID, CHOICE OF BLACK HEAT SHRINK, AND CABLE SPLIT LENGTHS ARE PRODUCTION PREFERENCE 1 A/R CICOIL CABLE 372R101-1 2 2 SMA CONNECTOR CONSMA007* 3 A/R BLACK HEAT SHRINK (-55°C TO +135°C) MANUFACTURING DISCRETION FN 5 SHIELDING: ULTRA FLEXIBLE, BRAIDED SHIELDS,WITH 90% NOMINAL COVERAGE 1 A/R CICOIL CABLE 372R101-2 2 4 SMA CONNECTOR CONSMA007* 3 A/R BLACK HEAT SHRINK (-55°C TO +135°C) MANUFACTURIN G DISCRETION 6 MINIMUM BEND RADIUS: 6X CABLE HEIGHT FOR INTERMEDIATE FLEX; 10X CABLE HEIGHT FOR CONTINUOUS FLEX C FC75-04-CA003 FC75-04-CA006 FC75-04-CA012 8 OUTER JACKET DUROMETER RATING: 65 (SHORE A) 9 TEMPERATURE RATING FOR CABLE: MFG --- MFG CICOIL LINX TECHNOLOG IES --- C FN 7 FLEX LIFE: 10,000,000 CYCLES NOMINAL BY RR CICOIL D LINX TECHNOLOG IES FLEXIBLE COAX 75 OHM, FC75-02-CAXXX QTY DESCRIPTION PART NUMBER 3 CONNECTIONS ARE ALL 1:1 4 CONDUCTORS: ULTRA FLEXIBLE, FINELY STRANDED, TINNED COPPER REV N/C 1 REVISION HISTORY DESCRIPTION DATE INITIAL RELEASE 09/06/2013 FLEXIBLE COAX 75 OHM, FC75-04-CAXXX QTY DESCRIPTION PART NUMBER 1 A/R CICOIL CABLE 372R101-4 2 8 SMA CONNECTOR CONSMA007* 3 A/R BLACK HEAT SHRINK (-55°C TO +135°C) MANUFACTURIN G DISCRETION MFG CICOIL LINX TECHNOLOG IES --- -65°C TO +165°C TEMPERATURE RATING FOR FINISHED ASSEMBLY: -20°C TO +125°C 10 OUTER JACKET DIELECTRIC STRENGTH: 450 VOLTS/MILS (17.7 kv/mm) B FN 11 *OR EQUIVALENT FC75-08-CA003 FC75-08-CA006 FC75-08-CA012 THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF CICOIL LLC AND ARE ISSUED IN STRICT CONFIDENCE AND SHALL NOT BE REPRODUCED OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE 0F EQUPMENT WITHOUT PERMISSION. 1 A/R CICOIL CABLE 372R101-8 2 16 SMA CONNECTOR CONSMA007* 3 A/R BLACK HEAT SHRINK (-55°C TO +135°C) MANUFACTURING DISCRETION DIMENSIONS ARE IN INCHES .X+/- 0.5 .XX+/-0.05 .XXX+/-0.005 ANGLES +/- 5 DEG [MM] QTY REQD NEXT ASSEMBLY FINAL ASSEMBLY --- DATE SIGNATURE 24960 AVENUE TIBBITTS, VALENCIA, CA 91355 www.cicoil.com 661-295-1295 DRAWN: rruiz CHECK JOHN PALAHNUK ENGINEER JOHN PALAHNUK 9/5/2013 TITLE 9/6/2013 FLEXIBLE COAX 9/6/2013 SIZE CAGE CODE DASH NO MFG CICOIL LINX B TECHNOLOG IES } VIEW PROJECTION STANDARD TOLERANCES UNLESS OTHERWISE NOTED A FLEXIBLE COAX 75 OHM, FC75-08-CAXXX QTY DESCRIPTION PART NUMBER MATERIAL: 19476 DRAWING NUMBER A REVISION FC-75-0X-CAXXX N/C APPLICATION SCALE DO NOT SCALE DRAWING 4 3 2 FILE: FC-75-0X (C).idw SHEET 1 OF 3 1
FC75-01-CA003 价格&库存
很抱歉,暂时无法提供与“FC75-01-CA003”相匹配的价格&库存,您可以联系我们找货
