True RMS AC Voltage Transducer
DIN RAIL / PANEL MOUNT, TRUE RMS
The CR4500 Series, True RMS Voltage Transducers and
Transmitters are designed for applications where AC voltage
waveforms are not purely sinusoidal. More precise and
accurate than other devices, these units are ideal in chopped
wave and phase fired control systems.
Applications
Phase fired controlled devices
Quickly varying voltage supplies
Chopped waveform drivers
Harmonic voltages
Features
35mm DIN rail mount or panel mount
Available with 0-5 VDC, 0-10VDC or 4-20 mADC output
24 VDC powered
Highest precision available
Outputs isolated from inputs
Connection diagram printed on case
CR4510 CR4511 CR4520
Transducers
C
Single Element
1.0 to 600 VAC Input Range
Regulatory Agencies
Recognized to meet UL 61010B-1
Constructed to meet CAN/CSA-C22.2, No. 61010-1-2004
Meets requirement of IEC 61010-1 and BS EN 61010-1
CR4550
CR4570
CR4560
CR4580
E199795
Three Element
Add suffix for input range
PART NUMBERS
CR4510
CR4511
CR4520
CR4550
CR4560
CR4570
CR4580
Single element with 0 - 5 VDC output
Single element with 0 - 10 VDC output
Single element with 4 - 20 mADC output
3-Phase 3-Wire with 0 to 5 VDC Output
3-Phase 3-Wire with 4 - 20 mADC Output
3-Phase 4-Wire with 0 to 5 VDC Output
3-Phase 4-Wire with 4 - 20 mADC Output
50
150
250
500
0-50 VAC
0-150 VAC
0-250 VAC
0-500 VAC
Ranges available up to and
including 600 VAC
* UL Recognized up to 300 Vac
CR Magnetics has a wide selection of Potential Transformers to extend the range of any part. Contact factory for more information.
The Professional
Energy Monitoring
Company
M N TI
ISO 9001:2008 Quality Management System
3500 Scarlet Oak Blvd. St. Louis MO USA 63122 V: 636-343-8518 F: 636-343-5119
Web: http://www.crmagnetics.com
40
E-mail: sales@crmagnetics.com
SPECIFICATIONS
Basic Accuracy:........................ 0.5%
Linearity:................................ 10% to 100% FS
Calibration:............................... True RMS Sensing
Thermal Drift:........................... 500 PPM/°C
Operating Temperature:........... 0°C to +60°C
Installation Category:............... CAT II
Vibration Tested To:................. IEC 60068-2-6,1995
Pollution Degree:..................... 2
Response Time:....................... 250 ms
Altitude:.................................... 2000 meter max.
Insulation Voltage:.................... 2500 Vdc
Supply Voltage:........................ 24 Vdc ±10%
Frequency Range:................... 20 Hz - 5 KHz
Cleaning:.................................. Water-dampened cloth
MTBF:......................... Greater than 100 K hours
Output Load:............... 4-20 mADC - 0 to 300 Ω
0-5 VDC - 2K Ω or Greater
Relative Humidity:......... 5% to 95%, Non-Condensing
Supply Current:
CR4510:........................ Typical 15mA
Max 25mA
CR4520:........................ Typical 25mA
Max 40mA
CR4550/70:................... Typical 20mA
Max 60mA
CR4560/80:................... Typical 55mA
Max 110mA
Torque Specs.:.............. 3.0 inch lbs. (0.4Nm)
Weight:.......................... 0.5 lbs.
C
[26.6]
1.05
9
8
7
6
5
1
2
3
4
INPUT 1
OUTPUT 1
9
8
7
6
5
OUTPUT
SUPPLY
SUPPLY
[3.3]
.13
Optional
Mounting
DIN RAIL
MOUNTING
CLIP
[73.1]
2.88
[83.3]
3.28
Top View
L2
L3
[30.4]
1.20
L1
L3-L1
1
2
[28.3]
1.12
L2
L3
L2-L3
9
8
7
6
3
4
[5.6]
.22
TYP
CR4520 Single Phase - 4 - 20 mADC Output
CR4510 Single Phase - 0 - 5 VDC Output
CR4511 Single Phase - 0 - 10 VDC Output
L1
[62.1]
2.45
L2-L3
9
8
7
6
3
4
L3-L1
1
2
L1-L2
5
L1-L2
[36.6]
1.44
End View
5
SUPPLY
[88.7]
3.49
SUPPLY
CR4560 3 Phase, 3 Wire - 4-20 mADC Output
CR4550 3 Phase, 3 Wire - 0 - 5 VDC Output
End View
[25]
.98
L1
L2
L3
N
1
2
3
4
[76.8]
3.02
[5.6]
.22
TYP
L3-N
9
8
7
6
5
L2-N
L1-N
CR4550
CR4560
[36.6]
1.44
CR4570
L2
L3
N
1
2
3
4
9
8
7
6
5
SUPPLY
[28.3]
1.12
[88.7]
3.49
L1
CR4570 3 Phase, 4 Wire - 0 - 5 VDC Output
L3-N
L2-N
L1-N
SUPPLY
CR4580 3 Phase, 4 Wire - 4 - 20 mADC Output
CR4580
OUTLINE DRAWING
CONNECTION DIAGRAM
USE CR MAGNETICS LOW AND MEDIUM VOLTAGE POTENTIAL TRANSFORMERS
(SECTION G)
NOTE: The building installation must have a switch or circuit-breaker that is in close proximity and within easy reach of the operator. The switch or circuit breaker
shall be marked as the disconnecting device for the equipment.
The Professional
Energy Monitoring
Company
M N TI
41
Transducers
1
2
3
4
INPUT 1
很抱歉,暂时无法提供与“CR4520-600”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2952.479061+383.17789
