58-024-1A
58-024-1A
    TPI(TPI 公司)
    CABLE ASSEMBLY RG58/U 24"
58-024-1A 数据手册
BNC to BNC COAX CABLE ASSEMBLIES 50 Ohm, 75 Ohm, 93 Ohm Features Molded BNC to BNC Cable Assemblies • UL Listed Cable: Ensures quality and consistency in the cable construction. • Boot is molded to cable connector for added strength: Limits the amount of bending the cable is exposed to at the connector to prevent cable breakage. • Gold center pins: Ensures that there is a high quality connection maintaining the best return loss in high definition applications. • Machined Brass Connectors: Unlike die-cast connectors, machined brass connectors have more precise tolerances, strength and positive mating meaning low signal loss for precise video and data applications. • 95% Shielding: Keeps unwanted RF interference from infiltrating your signal giving you nice, clean output. • 80º temperature rating: Applicable to any application found indoors. • Lengths Available up to 100 ft.: Easily route cables into other rooms or floors. • Individually bagged Specifications Conductor Insulation Braided Shielding Jacket General RG58 RG59 RG62 Material Bare Copper Copper Clad Steel No./mm 1/0.813 1/0.643 Material Low Density Polyethylene Color Natural Diameter (mm) 2.95 3.71 Material Bare Copper No./mm 16/7/0.12 16/7/0.12 Material Polyvinyl Chloride (PVC) Thickness (mm) 0.72 0.9 1 Color Black Outer Diameter (mm) 4.95 ±0.15 6.0 ±0.15 6.15 ±0.15 Tensile Strength 1,500 psi Nominal Impedance (Ohm) 53.5 73 93 Nominal Capacitance (pF/m) 93.5 68.9 44.3 Attenuation 100MHz (db/km) 138 125 102 Voltage Rating 30V UL Standard 1354 Cable Length Tolerance: 12 to 36 inch cables = +/- 1 inch Cables above 36 inches = +/- 1.5 inches RG58/U, BNC Male to Male Instrumentation & Data RG59/U, BNC Male to MaleVideo & General RG62/U, BNC Male to MaleComputer & Lab 50 Ohm 75 Ohm 93 Ohm Part No. 58-012-1M 58-024-1M 58-036-1M 58-048-1M 58-060-1M 58-072-1M 58-120-1M 58-180-1M 58-300-1M 58-600-1M 58-900-1M 58-1200-1M Length 12 inch 24 inch 36 inch 48 inch 60 inch 72 inch 10 feet 15 feet 25 feet 50 feet 75 feet 100 feet Part No. 59-012-1M 59-024-1M 59-036-1M 59-048-1M 59-060-1M 59-072-1M 59-120-1M 59-180-1M 59-300-1M 59-600-1M 59-900-1M 59-1200-1M Length 12 inch 24 inch 36 inch 48 inch 60 inch 72 inch 10 feet 15 feet 25 feet 50 feet 75 feet 100 feet Part No. 62-024-1M 62-036-1M 62-048-1M 62-060-1M Length 24 inch 36 inch 48 inch 60 inch Assembled BNC to BNC Cable Assemblies RG58/U, BNC Male to Male Instrumentation & Data 50 Ohm Part No. 58-024-1A 58-036-1A 58-048-1A 58-060-1A Length 24 inch 36 inch 48 inch 60 inch Copyright © 2010 Test Products International, Inc. Features
58-024-1A 价格&库存
很抱歉,暂时无法提供与“58-024-1A”相匹配的价格&库存,您可以联系我们找货
