4
3
2
FC50-01-CA003
FC50-01-CA006
FC50-01-CA012
D
NUMBER OF
CONDUCTORS
LENGTH IN FEET
ZONE
ALL
NOTES, UNLESS OTHERWISE SPECIFIED:
1 INSTALL CONNECTORS AND
HEAT SHRINK AS NEEDED
FN
2 THE ID, CHOICE OF BLACK
HEAT SHRINK,
AND CABLE SPLIT LENGTHS ARE
PRODUCTION PREFERENCE
FC50-02-CA003
FC50-02-CA006
FC50-02-CA012
3 CONNECTIONS ARE ALL 1:1
FC50-04-CA003
FC50-04-CA006
FC50-04-CA012
1
A/R
2
2
3
A/R
FN
1
A/R
2
4
7 FLEX LIFE: 10,000,000 CYCLES NOMINAL
3
A/R
8 OUTER JACKET DUROMETER RATING:
65 (SHORE A)
2
8
3
A/R
11 *OR EQUIVALENT
FN
B
FC50-08-CA003
FC50-08-CA006
FC50-08-CA012
THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF
CICOIL LLC AND ARE ISSUED IN STRICT CONFIDENCE AND SHALL NOT
BE REPRODUCED OR COPIED OR USED AS THE BASIS FOR THE
MANUFACTURE OR SALE 0F EQUPMENT WITHOUT PERMISSION.
SMA
CONSMA007*
CONNECTOR
BLACK HEAT
SHRINK
MANUFACTURING
(-55°C TO
DISCRETION
+135°C)
CICOIL CABLE
DIMENSIONS ARE IN INCHES
.X+/- 0.5
.XX+/-0.05
.XXX+/-0.005
ANGLES +/- 5 DEG
[MM]
QTY
REQD
NEXT
ASSEMBLY
FINAL
ASSEMBLY
CICOIL
LINX
TECHNOLOG
IES
CICOIL
CICOIL CABLE
SMA
CONNECTOR
BLACK HEAT
SHRINK
(-55°C TO
+135°C)
607R101-04
CICOIL
LINX
TECHNOLOG
IES
CONSMA007*
MANUFACTURIN
G DISCRETION
FLEXIBLE COAX 50 OHM, FC50-08-CAXXX
QTY DESCRIPTIO PART NUMBER
MFG
1
A/R
2
16
3
A/R
CICOIL CABLE
607R101-08
SMA
CONSMA007*
CONNECTOR
BLACK HEAT
SHRINK
MANUFACTURING
(-55°C TO
DISCRETION
+135°C)
DATE
SIGNATURE
24960 AVENUE TIBBITTS, VALENCIA, CA 91355 www.cicoil.com 661-295-1295
DRAWN:
rruiz
CHECK
JOHN PALAHNUK
ENGINEER
JOHN PALAHNUK
MATERIAL:
9/5/2013
TITLE
9/6/2013
FLEXIBLE COAX
9/6/2013
SIZE
19476
SCALE
DO NOT SCALE DRAWING
3
B
CICOIL
LINX
TECHNOLOG
IES
DRAWING NUMBER
A
REVISION
FC-50-0X-CAXXX N/C
APPLICATION
4
D
LINX
SMA
TECHNOLOG
CONSMA007*
CONNECTOR
IES
C
BLACK HEAT
SHRINK
MANUFACTURING
--(-55°C TO
DISCRETION
+135°C)
CAGE CODE
DASH
NO
607R101-02
VIEW PROJECTION
STANDARD TOLERANCES
UNLESS OTHERWISE NOTED
A
A/R
1
10 OUTER JACKET DIELECTRIC STRENGTH:
450 VOLTS/MILS (17.7 kv/mm)
607R101-01
FLEXIBLE COAX 50 OHM, FC50-04-CAXXX
MFG
FN
-65°C TO +165°C
TEMPERATURE RATING FOR FINISHED ASSEMBLY:
-20°C TO +125°C
CICOIL CABLE
FLEXIBLE COAX 50 OHM, FC50-02-CAXXX
MFG
6 MINIMUM BEND RADIUS: 6X CABLE HEIGHT
FOR INTERMEDIATE FLEX;
10X CABLE HEIGHT FOR CONTINUOUS FLEX
9 TEMPERATURE RATING FOR CABLE:
BY
RR
FLEXIBLE COAX 50 OHM, FC50-01-CAXXX
MFG
4 CONDUCTORS: ULTRA FLEXIBLE,
FINELY STRANDED, TINNED COPPER
5 SHIELDING: ULTRA FLEXIBLE, BRAIDED
SHIELDS,WITH 90% NOMINAL COVERAGE
C
REV
N/C
1
REVISION HISTORY
DESCRIPTION
DATE
INITIAL RELEASE 09/06/2013
2
FILE: FC-50-0X (C).idw
SHEET 1 OF 3
1
很抱歉,暂时无法提供与“FC50-02-CA003”相匹配的价格&库存,您可以联系我们找货
