4
3
2
FC75-01-CA003
FC75-01-CA006
FC75-01-CA012
D
NUMBER OF
CONDUCTORS
LENGTH IN FEET
FC75-02-CA003
FC75-02-CA006
FC75-02-CA012
ZONE
ALL
NOTES:
1 INSTALL CONNECTORS
AND HEAT SHRINK AS NEEDED
FLEXIBLE COAX 75 OHM, FC75-01-CAXXX
QTY
DESCRIPTION PART NUMBER
FN
2 THE ID, CHOICE OF BLACK
HEAT SHRINK,
AND CABLE SPLIT LENGTHS ARE
PRODUCTION PREFERENCE
1
A/R
CICOIL CABLE
372R101-1
2
2
SMA CONNECTOR
CONSMA007*
3
A/R
BLACK HEAT
SHRINK (-55°C
TO +135°C)
MANUFACTURING
DISCRETION
FN
5 SHIELDING: ULTRA FLEXIBLE, BRAIDED
SHIELDS,WITH 90% NOMINAL COVERAGE
1
A/R
CICOIL CABLE
372R101-2
2
4
SMA CONNECTOR
CONSMA007*
3
A/R
BLACK HEAT
SHRINK (-55°C
TO +135°C)
MANUFACTURIN
G DISCRETION
6 MINIMUM BEND RADIUS: 6X CABLE HEIGHT FOR
INTERMEDIATE FLEX;
10X CABLE HEIGHT FOR CONTINUOUS FLEX
C
FC75-04-CA003
FC75-04-CA006
FC75-04-CA012
8 OUTER JACKET DUROMETER RATING:
65 (SHORE A)
9 TEMPERATURE RATING FOR CABLE:
MFG
MFG
CICOIL
LINX
TECHNOLOG
IES
C
FN
7 FLEX LIFE: 10,000,000 CYCLES NOMINAL
BY
RR
CICOIL
D
LINX
TECHNOLOG
IES
FLEXIBLE COAX 75 OHM, FC75-02-CAXXX
QTY
3 CONNECTIONS ARE ALL 1:1
4 CONDUCTORS: ULTRA FLEXIBLE,
FINELY STRANDED, TINNED COPPER
REV
N/C
1
REVISION HISTORY
DESCRIPTION
DATE
INITIAL RELEASE 09/06/2013
FLEXIBLE COAX 75 OHM, FC75-04-CAXXX
QTY
1
A/R
CICOIL CABLE
372R101-4
2
8
SMA CONNECTOR
CONSMA007*
3
A/R
BLACK HEAT
SHRINK (-55°C
TO +135°C)
MANUFACTURIN
G DISCRETION
MFG
CICOIL
LINX
TECHNOLOG
IES
-65°C TO +165°C
TEMPERATURE RATING FOR FINISHED ASSEMBLY:
-20°C TO +125°C
10 OUTER JACKET DIELECTRIC STRENGTH:
450 VOLTS/MILS (17.7 kv/mm)
B
FN
11 *OR EQUIVALENT
FC75-08-CA003
FC75-08-CA006
FC75-08-CA012
THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF
CICOIL LLC AND ARE ISSUED IN STRICT CONFIDENCE AND SHALL NOT
BE REPRODUCED OR COPIED OR USED AS THE BASIS FOR THE
MANUFACTURE OR SALE 0F EQUPMENT WITHOUT PERMISSION.
1
A/R
CICOIL CABLE
372R101-8
2
16
SMA CONNECTOR
CONSMA007*
3
A/R
BLACK HEAT
SHRINK (-55°C
TO +135°C)
MANUFACTURING
DISCRETION
DIMENSIONS ARE IN INCHES
.X+/- 0.5
.XX+/-0.05
.XXX+/-0.005
ANGLES +/- 5 DEG
[MM]
QTY
REQD
NEXT
ASSEMBLY
FINAL
ASSEMBLY
DATE
SIGNATURE
24960 AVENUE TIBBITTS, VALENCIA, CA 91355 www.cicoil.com 661-295-1295
DRAWN:
rruiz
CHECK
JOHN PALAHNUK
ENGINEER
JOHN PALAHNUK
9/5/2013
TITLE
9/6/2013
FLEXIBLE COAX
9/6/2013
SIZE
CAGE CODE
DASH
NO
MFG
CICOIL
LINX
B
TECHNOLOG
IES
VIEW PROJECTION
STANDARD TOLERANCES
UNLESS OTHERWISE NOTED
A
FLEXIBLE COAX 75 OHM, FC75-08-CAXXX
QTY
MATERIAL:
19476
DRAWING NUMBER
A
REVISION
FC-75-0X-CAXXX N/C
APPLICATION
SCALE
DO NOT SCALE DRAWING
4
3
2
FILE: FC-75-0X (C).idw
SHEET 1 OF 3
1
很抱歉,暂时无法提供与“FC75-02-CA012”相匹配的价格&库存,您可以联系我们找货
