FC50-08-CA003
FC50-08-CA003
    CICOIL
    COAXCBL50OHM3'SMA-SMAPLUG
FC50-08-CA003 数据手册
4 3 2 FC50-01-CA003 FC50-01-CA006 FC50-01-CA012 D NUMBER OF CONDUCTORS LENGTH IN FEET ZONE ALL NOTES, UNLESS OTHERWISE SPECIFIED: 1 INSTALL CONNECTORS AND HEAT SHRINK AS NEEDED FN 2 THE ID, CHOICE OF BLACK HEAT SHRINK, AND CABLE SPLIT LENGTHS ARE PRODUCTION PREFERENCE FC50-02-CA003 FC50-02-CA006 FC50-02-CA012 3 CONNECTIONS ARE ALL 1:1 FC50-04-CA003 FC50-04-CA006 FC50-04-CA012 1 A/R 2 2 3 A/R FN 1 A/R 2 4 7 FLEX LIFE: 10,000,000 CYCLES NOMINAL 3 A/R 8 OUTER JACKET DUROMETER RATING: 65 (SHORE A) 2 8 3 A/R 11 *OR EQUIVALENT FN B FC50-08-CA003 FC50-08-CA006 FC50-08-CA012 THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF CICOIL LLC AND ARE ISSUED IN STRICT CONFIDENCE AND SHALL NOT BE REPRODUCED OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE 0F EQUPMENT WITHOUT PERMISSION. SMA CONSMA007* CONNECTOR BLACK HEAT SHRINK MANUFACTURING (-55°C TO DISCRETION +135°C) CICOIL CABLE DIMENSIONS ARE IN INCHES .X+/- 0.5 .XX+/-0.05 .XXX+/-0.005 ANGLES +/- 5 DEG [MM] QTY REQD NEXT ASSEMBLY FINAL ASSEMBLY CICOIL LINX TECHNOLOG IES --- CICOIL CICOIL CABLE SMA CONNECTOR BLACK HEAT SHRINK (-55°C TO +135°C) 607R101-04 CICOIL LINX TECHNOLOG IES CONSMA007* MANUFACTURIN G DISCRETION --- FLEXIBLE COAX 50 OHM, FC50-08-CAXXX QTY DESCRIPTIO PART NUMBER MFG 1 A/R 2 16 3 A/R CICOIL CABLE 607R101-08 SMA CONSMA007* CONNECTOR BLACK HEAT SHRINK MANUFACTURING (-55°C TO DISCRETION +135°C) --- } DATE SIGNATURE 24960 AVENUE TIBBITTS, VALENCIA, CA 91355 www.cicoil.com 661-295-1295 DRAWN: rruiz CHECK JOHN PALAHNUK ENGINEER JOHN PALAHNUK MATERIAL: 9/5/2013 TITLE 9/6/2013 FLEXIBLE COAX 9/6/2013 SIZE 19476 SCALE DO NOT SCALE DRAWING 3 B CICOIL LINX TECHNOLOG IES DRAWING NUMBER A REVISION FC-50-0X-CAXXX N/C APPLICATION 4 D LINX SMA TECHNOLOG CONSMA007* CONNECTOR IES C BLACK HEAT SHRINK MANUFACTURING --(-55°C TO DISCRETION +135°C) CAGE CODE DASH NO 607R101-02 VIEW PROJECTION STANDARD TOLERANCES UNLESS OTHERWISE NOTED A A/R 1 10 OUTER JACKET DIELECTRIC STRENGTH: 450 VOLTS/MILS (17.7 kv/mm) 607R101-01 FLEXIBLE COAX 50 OHM, FC50-04-CAXXX QTY DESCRIPTIO PART NUMBER MFG FN -65°C TO +165°C TEMPERATURE RATING FOR FINISHED ASSEMBLY: -20°C TO +125°C CICOIL CABLE FLEXIBLE COAX 50 OHM, FC50-02-CAXXX QTY DESCRIPTIO PART NUMBER MFG 6 MINIMUM BEND RADIUS: 6X CABLE HEIGHT FOR INTERMEDIATE FLEX; 10X CABLE HEIGHT FOR CONTINUOUS FLEX 9 TEMPERATURE RATING FOR CABLE: BY RR FLEXIBLE COAX 50 OHM, FC50-01-CAXXX QTY DESCRIPTIO PART NUMBER MFG 4 CONDUCTORS: ULTRA FLEXIBLE, FINELY STRANDED, TINNED COPPER 5 SHIELDING: ULTRA FLEXIBLE, BRAIDED SHIELDS,WITH 90% NOMINAL COVERAGE C REV N/C 1 REVISION HISTORY DESCRIPTION DATE INITIAL RELEASE 09/06/2013 2 FILE: FC-50-0X (C).idw SHEET 1 OF 3 1
FC50-08-CA003 价格&库存
很抱歉,暂时无法提供与“FC50-08-CA003”相匹配的价格&库存,您可以联系我们找货
FC50-08-CA003
  • 2+7888.871272+1025.31540
