10cm SMA plug male to SMA plug male Semi-Flexible-.141' cable RG402
CABLE PHYSICAL PROPERTIES
Material
Diameter(mm)
Silver Plated copper clad steel
1.Inner conductor
0.93
Silver Plated Copper
2.Insulation
PTFE
3.00
3.Outer conductor
Copper Tube
3.58
CABLE ELECTRICAL PROPERTIES
Nom. Capacitance Conductor to Shield(pF/m)
95.1
Nom. Characteristic Impedance(ohm)
50
Corona Extinction Voltage(VRMS@60Hz)
1.9
Voltage Withstanding (VRMS@60Hz)
5.0
Min. Bend Radius(Install)(mm)
12.5
Outer Conductor Integrity Temp.(℃)
175
Operating Temp. (℃)
-55~+125
Moding Frequency(GHz)
34
Max attenuation at 6GHz (dB)
0.3
Nom. Attenuation
Frequency(MHz)
Nom. Attenuation(≯dB/m)
500
0.26
1000
0.37
3000
0.72
5000
0.91
VSWR Response
Attenuation Response
很抱歉,暂时无法提供与“320160012”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 4+120.808844+15.62387
