CARAEN3C5F07990
CARAEN3C5F07990
    SWITCHCRAFT
CARAEN3C5F07990 数据手册
2-Meter Mini-Con-X® & EN3® Standard Cable Assemblies NPB 630 Blunt cut on opposite end for maximum flexibility High quality, factory overmolded connectors Color coded, tissue paper separated conductor wires for easy termination Cable selected by Switchcraft/ Conxall to withstand harsh environments Standard 2-Meter (79”) Lengths FEATURES CABLE SPECIFICATIONS • • • • • • • • • • • • • • High quality molded cables now available as a standard, off-the-shelf item Single ended cable with blunt cut Straight or right angle connector options 2, 3, 4, 6, or 8 conductor versions available Made in the USA Molded 360° Flex Relief (EN3™ only) Call factory for custom lengths and other configurable options See drawings on Switchcraft.com for detailed specifications Rated for 300 V -30° C TO +105° C temperature rating Jacket Material: 30 mils PVC, black Conductor Insulation: 15 mils PVC UV & water resistant UL Recognized, CSA Certified, and RoHS Compliant SWITCHCRAFT: 5555 N ELSTON AVE, CHICAGO, IL 60630-773.792.2700 -SALES@SWITCHCRAFT.COM CONXALL: 601 East WILDWOOD, VILLA PARK, IL 60181 - 630.834.7504 - SALES@CONXALL.COM 2-Meter Mini-Con-X® & EN3® Standard Cable Assemblies NPB 630 DETAILS AND AVAILABLE PART NUMBERS Seal Rating Voltage Rating Life Rating UV Resistance Flex Relief Configuration Straight, 2-pos, Male Straight, 2-pos, Female Straight, 3-pos, Male Straight, 3-pos, Female Straight, 4-pos, Male Straight, 4-pos, Female Straight, 5-pos, Male Straight, 5-pos, Female Straight, 6-pos, Male Straight, 6-pos, Female Straight, 8-pos, Female Right Angle, 2-pos, Male Right Angle, 2-pos, Female Right Angle, 3-pos, Male Right Angle, 3-pos, Female Right Angle, 4-pos, Male Right Angle, 4-pos, Female Right Angle, 5-pos, Male Right Angle, 5-pos, Female Right Angle, 6-pos, Male Right Angle, 6-pos, Female EN3® IP68, integrated O-ring 250V, AC/DC 600 Insertion/Withdrawal Cycles UL F1 Rated Materials Molded 360° Flex Relief EN3® Part Number CAEN3C2M07990 CAEN3C2F07990 CAEN3C3M07990 CAEN3C3F07990 CAEN3C4M07990 CAEN3C4F07990 CAEN3C5M07990 CAEN3C5F07990 CAEN3C6M07990 CAEN3C6F07990 CAEN3C8F07990 CARAEN3C2M07990 CARAEN3C2F07990 CARAEN3C3M07990 CARAEN3C3F07990 CARAEN3C4M07990 CARAEN3C4F07990 CARAEN3C5M07990 CARAEN3C5F07990 CARAEN3C6M07990 CARAEN3C6F07990 Mini-Con-X® IP67, separate O-ring 300V, AC/DC 300 Insertion/Withdrawal Cycles Not Rated (Custom UV rated cables available, call factory) Not Available Mini-Con-X® Part Number CA62802P07990 CA62802S07990 CA62803P07990 CA62803S07990 CA62804P07990 CA62804S07990 CA62805P07990 CA62805S07990 CA62806P07990 CA62806S07990 CA62808S07990 CARA62802P07990 CARA62802S07990 CARA62803P07990 CARA62803S07990 CARA62804P07990 CARA62804S07990 CARA62805P07990 CARA62805S07990 CARA62806P07990 CARA62806S07990 VISIT WWW.SWITCHCRAFT.COM FOR MORE PRODUCTS AND DETAILED SPECIFICATIONS 2-Meter Mini-Con-X® & EN3® Standard Cable Assemblies NPB 630 CONNECTOR DIMENSIONS (Ref Only) 1.50 38.1 POLARIZATION KEY 6 O'CLOCK 1.375 [34.9] POLARIZATION KEY 12 O'CLOCK 0.92 23.4 0.70 17.8 1.57 39.8 0.70 17.8 1.109 [28.2] 1.69 42.9 1.92 48.6 0.71 18.0 2.46 62.5 1.88 47.8 0.65 16.5 CAEN3________ CARAEN3_______ CA6280________ CARA6280________ CONTACT LAYOUTS (Connector Face Side) KEY KEY 1 2 2 4 1 3 3 POSITION #20 PIN & SOCKET CONTACT 2 4 POSITION #20 PIN & SOCKET CONTACT 2 3 KEY KEY 1 5 4 3 2 POSITION #20 PIN & SOCKET CONTACT KEY KEY 1 5 POSITION #20 PIN & SOCKET CONTACT 1 4 1 7 8 6 2 6 3 5 3 5 4 6 POSITION #20 PIN & SOCKET CONTACT 2 8 POSITION #20 SOCKET CONTACT Mating Parts Cable Part Number CAEN3C2M07990 CAEN3C2F07990 CAEN3C3M07990 CAEN3C3F07990 CAEN3C4M07990 CAEN3C4F07990 CAEN3C5M07990 CAEN3C5F07990 CAEN3C6M07990 CAEN3C6F07990 CAEN3C8F07990 CARAEN3C2M07990 CARAEN3C2F07990 CARAEN3C3M07990 CARAEN3C3F07990 CARAEN3C4M07990 CARAEN3C4F07990 CARAEN3C5M07990 CARAEN3C5F07990 CARAEN3C6M07990 CARAEN3C6F07990 CARAEN3C8F07990 Mating Cable-to-Cable* EN3L2FX EN3L2MX EN3L3FX EN3L3MX EN3L4FX EN3L4MX EN3L5FX EN3L5MX EN3L6FX EN3L6MX EN3L8MX EN3L2FX EN3L2MX EN3L3FX EN3L3MX EN3L4FX EN3L4MX EN3L5FX EN3L5MX EN3L6FX EN3L6MX EN3L8MX Mating Panel Mount* EN3P2FX EN3P2MX EN3P3FX EN3P3MX EN3P4FX EN3P4MX EN3P5FX EN3P5MX EN3P6FX EN3P6MX EN3P8MX EN3P2FX EN3P2MX EN3P3FX EN3P3MX EN3P4FX EN3P4MX EN3P5FX EN3P5MX EN3P6FX EN3P6MX EN3P8MX Column1 Cable Part Number CA62802P07990 CA62802S07990 CA62803P07990 CA62803S07990 CA62804P07990 CA62804S07990 CA62805P07990 CA62805S07990 CA62806P07990 CA62806S07990 CA62808S07990 CARA62802P07990 CARA62802S07990 CARA62803P07990 CARA62803S07990 CARA62804P07990 CARA62804S07990 CARA62805P07990 CARA62805S07990 CARA62806P07990 CARA62806S07990 CARA62808S07990 Mating Cable-to-Cable* 8282-2SG-3DC 8282-2PG-3DC 8282-3SG-3DC 8282-3PG-3DC 8282-4SG-3DC 8282-4PG-3DC 8282-5SG-3DC 8282-5PG-3DC 8282-6SG-3DC 8282-6PG-3DC 8282-8PG-3DC 8282-2SG-3DC 8282-2PG-3DC 8282-3SG-3DC 8282-3PG-3DC 8282-4SG-3DC 8282-4PG-3DC 8282-5SG-3DC 8282-5PG-3DC 8282-6SG-3DC 8282-6PG-3DC 8282-8PG-3DC Mating Panel Mount* 7282-2SG-300 7282-2PG-300 7282-3SG-300 7282-3PG-300 7282-4SG-300 7282-4PG-300 7282-5SG-300 7282-5PG-300 7282-6SG-300 7282-6PG-300 7282-8PG-300 7282-2SG-300 7282-2PG-300 7282-3SG-300 7282-3PG-300 7282-4SG-300 7282-4PG-300 7282-5SG-300 7282-5PG-300 7282-6SG-300 7282-6PG-300 7282-8PG-300 *Additional configurations, backshell & grommet sizes, and mounting styles available. Visit Switchcraft.com for full product listing. VISIT WWW.SWITCHCRAFT.COM FOR THE MOST UP-TO-DATE PRODUCT SPECIFICATIONS
CARAEN3C5F07990 价格&库存
很抱歉,暂时无法提供与“CARAEN3C5F07990”相匹配的价格&库存,您可以联系我们找货
